Here I sit waiting on a tow truck. - Diesel Forum - TheDieselStop.com
 9Likes
post #1 of 23 (permalink) Old 01-08-2019, 07:05 PM Thread Starter
With fire extinguisher in hand I'm wondering why my grounds for my motor burst into flame. Can anyone help me? Or has this happen to anyone?
90 f350 2wd 7.3idi non T 5speed
DevilDog6154 is offline
post #2 of 23 (permalink) Old 01-08-2019, 07:34 PM
bugman's Avatar
My Photos: (12)
Loose grounds and grease equal heat and then fire.
bugman is offline
post #3 of 23 (permalink) Old 01-08-2019, 08:31 PM Thread Starter
ok so the ground on the bottom of the motor did not burn just the one from the battery on driver side to front by radiator and the two from the back of motor to the firewall. does that change anything?
post #4 of 23 (permalink) Old 01-08-2019, 09:09 PM
bugman's Avatar
My Photos: (12)
I would still suspect a bad connection on the ground.
But if multiple ones burned then I would start looking at a overload problems somewhere
bugman is offline
post #5 of 23 (permalink) Old 01-08-2019, 10:21 PM Thread Starter
can you give a example?
post #6 of 23 (permalink) Old 01-09-2019, 08:57 PM
Electric fuel pump? More lights than the circuit can handle? A high resistance short that isn't bad enough to blow fuses yet? Too big a fuse in a shorted circuit? Air conditiong compressor locking up? Starter solenoid stuck? Shorted battery? The only way you're going to find it is to dig in and start checking.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #7 of 23 (permalink) Old 01-09-2019, 10:20 PM
ArcticDriver's Avatar
I am no electrical expert but from what you describe I would think there was alot of amperage involved and not many things could create that draw or short. Those grounds are each larger gauge wires, aren’t they? If the short was from an accessory then I would think the smaller wiring specific to the accessory would have melted or blown a fusible link or a fuse before you saw enough continued amperage to heat up and start a fire through a larger gauge ground.
As was stated above, an overload.
Have you looked at your fuse panel? Can you shine a light into the back of the panel?
Do all of your accessories still function properly?
SOLD:
ArcticDriver is offline
post #8 of 23 (permalink) Old 01-10-2019, 07:06 AM
12v is the most fire prone voltage, add the fact it is DC.
Grounds need to be clean, tight and well secured from becoming lose.
So start from there, check the wiring run from the starter to both the + terminals, ensure no chaffing of the wire and that all connections are clean and torqued.
Do the same for the grounds, then start looking at other places. A little resistance makes big heat when dealing with low voltage I^2R = heat in watts
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
post #9 of 23 (permalink) Old 01-10-2019, 11:23 PM Thread Starter
Thank you all for your help. The starter was acting up the day before and day the fire happen so does that mean it caused it?
post #10 of 23 (permalink) Old 01-11-2019, 05:10 AM
The starter would be the type of heavy amperage draw I was thinking of in an earlier post but I don't know if the starter acting up is the cause or just a symptom.
Did the engine actually start when the fire occurred?
Have you inspected the batteries and checked their voltage?
Have you inspected and improved the ground connections yet to both the frame and the starter that were damaged?
Have you attempted to start the truck since this happened? I am not suggesting you attempt to start it, I just wonder if you have tried. I would inspect the starter before attempting to supply power to it again.
I hate to speculate without you first doing a further visual inspection of the starter but my dad reminded me of a starter on an old tractor that failed to disengage many years ago and the engine rpm kept rotating the starter and it burned up. He remembers the starter actually became a generator and produced current. This back amperage then started burning up wiring. (Fortunately there is not much wiring on those... Lol
It was an old WD45 with its original 6v converted to a 12v but the problem was it was a push button type starter. The push button had either corroded or maybe had ice build up and remained pushed in rather than springing back out once the engine turned over.
I guess it would be possible for this to have happened with your starter if the solenoid stayed engaged.
SOLD:
post #11 of 23 (permalink) Old 01-11-2019, 11:12 PM Thread Starter
The motor was running when it happen even after the power loss. The only reason the motor shut off was cause my foot come off the clutch pedal. No I haven't check anything it's at a friend's shop so he can do the assessment for the insurance.
post #12 of 23 (permalink) Old 01-12-2019, 03:12 AM
I hope you will let us know the results.
8gitmusik1 likes this.
SOLD:
post #13 of 23 (permalink) Old 01-13-2019, 09:29 AM Thread Starter
yea i will soon as i know.
post #14 of 23 (permalink) Old 01-30-2019, 12:38 AM Thread Starter
so i got my truck back, now i need a new wiring harness for it. does anyone know where i might find one?
post #15 of 23 (permalink) Old 01-30-2019, 08:12 AM
bugman's Avatar
My Photos: (12)
Junk yard
bugman is offline
