How NOT to start an engine on a stand - Diesel Forum - TheDieselStop.com
 14Likes
  • 3 Post By LMJD
  • 2 Post By klhansen
  • 2 Post By chuckster57
  • 3 Post By stumpman
  • 2 Post By oldrebuiltdodge
  • 1 Post By narmalee
  • 1 Post By oldrebuiltdodge
post #1 of 14 (permalink) Old 03-07-2018, 10:59 AM Thread Starter
My Photos: (27)
Years ago a Detroit Diesel engine rep came to our shop for a yearly engine info update. He brought up the fact that in his travels he sees diesel mechanics now and then starting an engine momentarily after a re-assembly or whatever with absolutely no coolant. He stressed even for a few seconds very high combustion heat is created with absolutely no way for it to dissipate whatsoever. After thinking about it later, makes perfect sense. First, due to the trapped heat with nowhere to go, most all piston ring tension is probably quickly shot. Can't do exhaust valves much good either. And sure enough, there was a guy, among others, on U-tube who ran an engine on a stand for a good 2 minutes, zero coolant, then a few weeks later he was asking why all the blue/white exhaust smoke and oil consumption (bad rings, duh) . There's an "expert" on FTE with a video right now proudly firing one up with no coolant, (same guy just grenaded one of his rebuilds after 60 miles but that's another story). Point is, just because you see some Clown do something on U-tube to his IDI diesel doesn't mean it's the right thing to do.
LMJD is offline
post #2 of 14 (permalink) Old 03-07-2018, 10:40 PM
klhansen's Avatar
My Photos: (180)
But, Wait!! Everything you see on the internet is true, isn't it?
), AIS,
regulated return,
klhansen is offline
post #3 of 14 (permalink) Old 03-07-2018, 11:05 PM
chuckster57's Avatar
Only if the pictures are posted to prove it
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 14 (permalink) Old 03-08-2018, 08:03 AM
No picture it never happened.
Randy 4614 is offline
post #5 of 14 (permalink) Old 03-08-2018, 08:34 AM Thread Starter
My Photos: (27)
Here's one of many from the old pro, lots of ether and an overworked starter and you're good to go--ask and you shall receive:
www.youtube.com/watch?v=qDPln0HtiZw
LMJD is offline
post #6 of 14 (permalink) Old 03-08-2018, 08:54 AM
Thatís funny stuff. Iím surprised the amount of ether he sprayed didnít make him pass out.
LMJD and Dogbone7.3 like this.
Train Horns:
post #7 of 14 (permalink) Old 03-08-2018, 09:23 AM
it probably did they had 4 takes
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #8 of 14 (permalink) Old 03-08-2018, 11:40 AM
Steve83's Avatar
I've seen a guy start & run a gasser hanging from a chain on a cherry picker. It danced even more than that 6.9 on the pallet.
Steve83 is offline
post #9 of 14 (permalink) Old 03-10-2018, 02:19 PM
Some people should not be in the gene pool!!!
LMJD and chuckster57 like this.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #10 of 14 (permalink) Old 03-10-2018, 07:44 PM
narmalee's Avatar
oh this is priceless...
"oh good sign, we are getting smoke out the exhaust now... also smoke off the battery terminal..."
LMJD likes this.
-'97 F250HD 4x4 7.3-
-'99 Cobra 426w-
-'76 LS408 Stingray-
-'93 302 Camaro on the juice-
narmalee is offline
post #11 of 14 (permalink) Old 03-11-2018, 10:56 AM Thread Starter
My Photos: (27)
Yep, and interestingly enough he's still dishing out advice like crazy even after admitting he installed a front crankshaft seal and rear main seal backwards.
LMJD is offline
post #12 of 14 (permalink) Old 03-11-2018, 02:51 PM
And sadly people are soaking it uplike it is gospel
LMJD likes this.
post #13 of 14 (permalink) Old 03-16-2018, 05:13 PM
Oh man, just catching up to this. Notable jump-cut at aprx. 3:05, garage door conspicuously goes from down to up. Golly, wonder why.....
madpogue is offline
post #14 of 14 (permalink) Old 03-16-2018, 05:59 PM
Maybe charging up the ONE battery, or replacing the burned out starter? Take your pick
