How to source a new vacuum resevoir/canister? - Diesel Forum - TheDieselStop.com
 4Likes
post #1 of 24 (permalink) Old 05-12-2019, 12:03 AM Thread Starter
lexxxel's Avatar
My vacuum reservoir, the metal can thing on the driver's side fender area, seems to be leaking... I have looked everywhere and nowhere seems to have this part listed. Anyone know where to get one? Or a part number? Being steel these tend to rot... can't believe they don't make a replacement...
'91 F-250 7.3idi XLT Lariat Supercab
Non-Turbo, Bone Stock
E4OD 4x2 4.10 non-posi
6 full digit mechanical odometer (7 slots)
155,000 miles (250,000km)
still Minty Fresh-ish
Sold my old 90 reg cab @340,000 miles (550,000km)
Still running I'm sure...
lexxxel is offline
post #2 of 24 (permalink) Old 05-12-2019, 01:47 PM
Steve83's Avatar
They do - it's just not steel. Browse the JYs; any vacuum reservoir from any make/model will work - especially those with the same number of nipples as your truck's. The plastic dual-chamber version was used at least from '87-03, so they're very common:
(phone app link)
The single-chamber version is slightly less-common, but still easy to find.
(phone app link)
If you really want a steel one...
(phone app link)
(phone app link)
Steve83 is offline
post #3 of 24 (permalink) Old 05-17-2019, 12:15 AM
Why not make your own out of a couple of fittings and an old ammo can? Or fittings and pretty much any kind of container that would stand up to the use?
89 F250 XLT Lariat 7.3idi C6 4WD
92 F250 XLT Lariat 7.3idi E4OD 4WD
Selador is offline
post #4 of 24 (permalink) Old 05-17-2019, 02:11 AM
I made one with PVC pipe and end caps.
DENNY
DENNY is offline
post #5 of 24 (permalink) Old 05-18-2019, 06:52 PM
DENNY
Use thread adapters, and you even have a place to hook up the hoses
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #6 of 24 (permalink) Old 05-18-2019, 11:54 PM Thread Starter
lexxxel's Avatar
How big of a pipe? Like sewer abs pipe?
Not sure how to put in the thread adapter, or even what it is... end caps make sense but how do you add nipples that don't leak?
lexxxel is offline
post #7 of 24 (permalink) Old 05-18-2019, 11:56 PM Thread Starter
lexxxel's Avatar
Will this part work? Can't see a size anywhere, but it's from a gasser ford
https://www.oemfordpart.com/oem-part...oir-d5tz9e453a
lexxxel is offline
post #8 of 24 (permalink) Old 05-18-2019, 11:58 PM
Drill a slightly undersized hole into the pipe cap. Probably best to do this after you have glued on the cap. And in the area where the cap and pipe overlap and are glued. That way you have double the thickness of plastic.
Screw the brass fitting into the hole. It will make it's own threads into the plastic.
Remove the fitting, coat the threads with silicone adhesive. Re-install the fitting. Let cure completely.
Done.
This works for making reservoirs for pressure up to several hundred pounds. It certainly should hold up to the less than 30 pounds of vacuum our systems must produce.
Selador is offline
post #9 of 24 (permalink) Old 05-19-2019, 11:03 AM
Steve83's Avatar
As I said: ANY vacuum reservoir will work. But that's an insane price for a part that's likely to fail again the same way.
Steve83 is offline
post #10 of 24 (permalink) Old 05-19-2019, 02:34 PM
RT
RT's Avatar
Science Nerd Alert. 30 pounds of vacuum feels like a typical American measuring unit. Like bullet velocity per square degrees Fahrenheit. Anyway, -30 (ok -29.92) inches of mercury is an absolute vacuum which is equivalent to -14.7 psi. In metric, that would be 0 torr (mmHg)
RT is offline
post #11 of 24 (permalink) Old 05-19-2019, 02:51 PM
bugman's Avatar
My Photos: (12)
In the long run I think that I would make one out of PVC, but then I like doing that kind of stuff.
Other than that it looks like it is junkyard raiding time.
bugman is offline
post #12 of 24 (permalink) Old 05-21-2019, 01:35 PM
dieselpro7's Avatar
https://www.fordpartsprime.com/ has a lot of hard to find, vintage and 'discontinued' OEM Ford parts. Check them out. I like buying on their site because their prices are cheaper than dealer.
dieselpro7 is offline
post #13 of 24 (permalink) Old 05-21-2019, 04:44 PM
klhansen's Avatar
My Photos: (180)
DO NOT use plastic pipe of any kind for a pressure reservoir, especially several hundred psi. The energy stored in the compressed air would be dangerously released if the plastic were to rupture. Even plastic shrapnel can kill you.
), AIS,
regulated return,
klhansen is offline
post #14 of 24 (permalink) Old 05-22-2019, 06:28 PM
Plastic pipe within the parameters of its design ratings is perfectly safe to use. I would definitely NOT put several hundred psi on it, but for 20 to 25 inches HG,vacuum (lack of pressure) I don't see any trouble. If there were a problem that it couldn't stand it, it would simply collapse, or implode. Either way, I don't see a safety concern there, nor do I see a piece of schedule 40 pipe having any trouble at all.
jleedog likes this.
post #15 of 24 (permalink) Old 05-22-2019, 09:32 PM
I'll give you the shrapnel point. I wouldn't want to be around if it exploded.
But... PVC pipe is rated for it.
Read the pipe the next time you are in lowes or home depot.
Or just read these...
PVC Schedule 40 Pressure/DWV Pipe | Heritage Plastics | PVC Conduit | Electrical and Plumbing
https://www.aetnaplastics.com/site_m...Dimensions.pdf
Selador is offline
Similar Threads
'2008 F250 - No 4x4 odonnks 6.4L Power Stroke Engine and Drivetrain 43 07-04-2019 02:13 PM
One more time...A/C blowing on defrost only FD_CaptainK 1999-2007 General Questions 5 08-30-2010 07:12 PM
vrv amsamu 7.3L IDI Diesels (Not Power Strokes) 4 07-28-2009 02:14 PM
Vacuum problem diagnosis - guidance needed digimojo 6.9L IDI Diesels (Not Power Strokes) 9 04-02-2007 12:20 AM
4 x 4 Vacuum Valve Problem? rocinbaja '99 & up 7.3L Power Stroke Engine and Drivetrain 18 05-10-2005 11:45 PM
