idi return line question - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-03-2013, 01:30 PM Thread Starter
1993 idi ats turbo do I have to buy a return line repair kit to fix a leaky line or can I just buy 5/16 fuel line ? Does it have to be high pressure hose or will standard hose work? Is the fuel hose specific to diesel or will standard gas line work ? Any help appreciated
dmuet84 is offline
post #2 of 5 (permalink) Old 02-03-2013, 01:38 PM
93blklightning's Avatar
your better off to buy a return line kit from a diesel shop or on line like Pennsacola Diesel it includes the lines (you need), the caps ( you'll probably need cause they usually break trying to replace them) and the o-rings you"ll need cause they usually go bad or start leaking if you bump the caps ( if they've been on a awhile ). the kit typically goes for around $30.00.
1992 F- 250 ZF 5spd,4wd,7.3 idi, K&N air filter, Holley red electric fuel pump, 3/55 gears, Lund cab visor, Ranchhand headache rack, diamond steel bed rails, American Racing aluminium wheels,gooseneck ball in bed, v-5 hitch,cab lights.Almost done with my conversion, reg cab L-bed to ext cab s-bed lookin good Motor is out of '91 F-Superduty unknown miles ,280,000 on truck. also got a 1999.5 F-250 Superduty,7.3 powerstroke,automatic transmission,xlt lariet,extend cab long bed (big truck), 150,000 miles,v-5 hitch
93blklightning is offline
post #3 of 5 (permalink) Old 02-03-2013, 02:06 PM
Napa also has a return line kit with the newer caps, proper hose and the clamps it was about $100 cdn when I bought it and they had it in the store.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
post #4 of 5 (permalink) Old 02-05-2013, 02:19 PM
typefour's Avatar
the pensacola kit will leak ina few months, they use cheap hose, the kits i use/provide german made hose that holds up for years. mine have 100k on them.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
made 218hp/461tq on a mustang dyno lasst dec with 80k on the rebuild
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
typefour is offline
post #5 of 5 (permalink) Old 02-05-2013, 05:31 PM
You need lines rated for Diesel fuel, gas hoses will not work as the diesel will soften and dissolve the hoses.
Alvin Mitchell
Pablo Montana
1983 F250 4X4 4.10 gears 4 speed dana 50 center/44 outers Dana 70 rear
Mitchalvin is offline
