Injector Pop pressure - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 20 (permalink) Old 11-07-2010, 08:18 AM
I built one out of a 2 ton Porta Power pump. The fittings were fcrom McMaster-Carr, this was for the 617 Mercedes injectors, but it will work for any diesel injectors with some fittings changing. This design called for a liquid filled gauge, but I've been told that a dry gauge with a ball valve (to check chatter) is more accurate. Here's the thread that got me started:
Easy homemade pop tester - PeachParts Mercedes ShopForum
Originally Posted by archangel View Post
I looking to put together an injector pressure tester and need to find an adapter to fit the line to a pipe thread.
Anyone have an idea where I can get it.
Grainger does not have the fitting, although I did get the 2000 PSI gauge there for $14 and change.
Also, an idea for a cheap pump other than an adapted 2000 lb bottle jack?
8080 is offline
post #17 of 20 (permalink) Old 11-07-2010, 09:30 AM
Would you just happen to have that part number for the fittings that were purchased from McMaster-Carr?
Even though I'm in the process of posting listings to sell my truck, I would like to finish the project.
5 Minutes later.......................................
And then I looked at the link you provided.
Just to double check that these are the parts you refer to?
Primarily for me, the 6MM tube one?
Whatever the pipe fittings are I can adapt as I have yet to machine the bottle jacks ram replacement part, so I can tap the internal threads to whatever size is needed.
McMaster Carr
5269K311 $3.47
METRIC STEEL COMPRESSION TUBE FITTING, ADAPTER FOR 6 MM TUBE OD X 1/8" NPT MALE PIPE
50925K343 $1.53
COMPACT EXTREME-PRESSURE STEEL THRD FITTING, 3/8"MALE X 1/8"FEM PIPE, HEX HEAD BUSHING,6000 PSI
3845K23 $18.49
GLYCERIN-FILLED GAUGE - 1% MID-SCALE ACCURACY, 2-1/2" DIAL, 1/4" BOTTOM, 0 - 3000 PSI
50925K345 $1.30
COMPACT EXTREME-PRESSURE STEEL THRD FITTING, 3/8"MALE X 1/4"FEM PIPE,HEX HEAD BUSHING, 6000 PSI
50925K198 $7.11
COMPACT EXTREME-PRESSURE STEEL THRD FITTING, 3/8" PIPE, FEMALE X FEMALE X MALE TEE, 4500 PSI
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19
city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
archangel is offline
post #18 of 20 (permalink) Old 11-08-2010, 08:27 AM
McMaster Carr
5269K311 $3.47
50925K343 $1.53
3845K23 $18.49
50925K345 $1.30
50925K198 $7.11
COMPACT EXTREME-PRESSURE STEEL THRD FITTING, 3/8" PIPE, FEMALE X FEMALE X MALE TEE, 4500 PSI[/QUOTE]
Since you are using a bottle jack, I would guess (but I'm not certain) that you can set it up to use the 6mm fitting, I just can't say. I used a portapower copy off eBay and had to find a different fitting for that spot, but it was just off the rack, I don't know the size. So you would have to consider the size of the existing outlet and adjust as necessary. The rest of the fittings worked as listed. I am going to utilize a ball valve and a dry gauge instead of, or in conjunction with the glycerin filled valve due to some stated concerns about correct readings when doing the chatter test. That and the dry gauge is a 4.5" 1% 4000 PSI, which is easier to read.
8080 is offline
post #19 of 20 (permalink) Old 11-08-2010, 06:48 PM
Keep a eye on ebay I got the Ford Rotunda injector pop tester from ebay years back. Lots of dealers have closed so lots of the Rotunda tools end up on ebay
83 F-250 sc xlt 6.9 turbo 4-speed 4.10s 85 F350 rc 6.9 C-6 dually 3.55 89 F350 CC xlt dually 7.3 5-speed 4.10s 91 F350 rc 7.3 E4od 3.55 93 F350 cc 7.3 E4od 3.55
japar is offline
post #20 of 20 (permalink) Old 05-03-2019, 08:45 PM
OK -so I bought a Chinese tester, guess what? It works! My old injectors were all over the map, most 1850-1900, one was 1400, one was 2400! Plus they didn't "pop" they kinda just took a diesel piss. SO .. I ordered a matched set from Pensacola Diesel. Remanufactured, 189.00. They look snazzy, BUT-- they test at 1550-1650. They do "pop" good. Chatter good.. but the low pressure concerns me..
Side note- 1991 F250 7.3L IDI, original injector code "E", the ones from Pensacola Diesel say "3008". No letter code. Weird.
antigrav1117 is offline
