Pulling Codes - Page 3 - Diesel Forum - TheDieselStop.com
 1Likes
post #31 of 48 (permalink) Old 02-12-2018, 08:47 AM Thread Starter
Originally Posted by Mark Kovalsky View Post
As was said above you can't have two digit and three digit codes in the same computer. It won't do that.
Can you post a video of the test?
How do I do that?
94 F350 7.3 IDI Turbodiesel 4x2 CC E4OD transmission, 4.10 gear ratio, 10.25 ring gear, limited slip, single rear wheels, long bed, Tru-Cool Max 45k transmission cooler l
Hoko is offline
post #32 of 48 (permalink) Old 02-12-2018, 09:46 AM
Mark Kovalsky's Avatar
My Photos: (6)
Put the video on a hosting site such as YouTube and post a link to it.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #33 of 48 (permalink) Old 02-12-2018, 10:07 PM Thread Starter
Ok here is a video of the test light codes
Hoko is offline
post #34 of 48 (permalink) Old 02-12-2018, 10:32 PM
My Photos: (6)
I saw 11, 11, 1, 14, and 14.
11 means there was no error detected while the test was running. 1 is a separator between on demand codes and continuous codes. 14 means the engine RPM sensor that is used to control the transmission isn't working. It's either a bad sensor or a damaged wire to the sensor.
Mark
Former
post #35 of 48 (permalink) Old 02-12-2018, 11:58 PM
Does the tach work?
madpogue is offline
post #36 of 48 (permalink) Old 02-13-2018, 09:17 AM Thread Starter
Originally Posted by madpogue View Post
Does the tach work?
Occasionally, would that mean the tach needs to be replaced or could something else be causing it to malfunction? There are times when it is fine for long periods of time, although even when it works, the needle doesn't come off of zero till about 1/3 throttle.
Hoko is offline
post #37 of 48 (permalink) Old 02-13-2018, 09:29 AM
The tach sensor is located on the inj pump gear cover.
Early '99 F250(02-98) 192,000mi,2wd,auto,Extra cab longbed,Bak Flip tonneau cover,AIS,4" turbo back exhaust,ITP regulated fuel return,SS HPX line,203 Tstat,Evans coolant,Isspro EV2 gauges trans temp,boost,EGT,fuel pressure,John Wood HD 4R100,6.0 cooler,DP Tuner F5 chip,Terminator Scangauge
1989 F250 4x4 7.3 IDI w Banks Sidewinder turbo, 149,000 mi, Regular cab, E4OD, 8600 GVWR, 4.10 LS, Isspro EV2 gauges EGT, Trans temp, Coolant temp, Oil press, Boost press
0298PSD is offline
post #38 of 48 (permalink) Old 02-13-2018, 11:34 AM Thread Starter
Thx!
I'm assuming the tach sensor is also the engine rpm sensor?
Hoko is offline
post #39 of 48 (permalink) Old 02-13-2018, 12:35 PM
Yes, the tach sensor provides the RPM signal to the TCM as well as the tach.
madpogue is offline
post #40 of 48 (permalink) Old 02-13-2018, 01:10 PM Thread Starter
Wow I was way off on reading that code. Thank you for translating that code for me Mark.
Hoko is offline
post #41 of 48 (permalink) Old 02-14-2018, 10:24 AM Thread Starter
What modules does a 94 7.3 IDI F350 have? A supplier told me my truck has an IDM, PCM and a TCM. Is that right?
Hoko is offline
post #42 of 48 (permalink) Old 02-14-2018, 10:54 AM
chuckster57's Avatar
‘94 is the year of 3 flavors
IDI non turbo
IDI Turbo
Power stroke (mid year).
You don’t have an IDM,
Train Horns:
PM please not visitor message
chuckster57 is offline
post #43 of 48 (permalink) Old 02-14-2018, 11:05 AM Thread Starter
IDI non turbo
IDI Turbo
The IDM must have showed up on the Powerstroke
Thx
Hoko is offline
post #44 of 48 (permalink) Old 02-14-2018, 11:13 AM
My Photos: (27)
So the best thing you can do regarding parts or whatever if it's engine related, to avoid confusion say you have a '91 or '92.
LMJD is offline
post #45 of 48 (permalink) Old 02-14-2018, 01:37 PM
Thx
Correct. A critical feature of the IDI engine is that it's completely mechanically controlled. There are no "modules", because there would be nothing to connect them to. Manual trucks don't even have a diagnostic connector. The only exceptions are later vehicles with ABS and/or electronic cruise control. But ABS has no connection to the engine, and cruise control only connects to the throttle arm on the IP.
A '91 is a different _truck_; ordering parts for it would be a bad idea. '92 also did not have a factory turbo. A '93 would be a closer match. Also, somewhere along that timeline, the belt drive switched from V-belt to serpentine.
79jasper likes this.
madpogue is offline
