Radiator fan clutch - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-01-2010, 10:14 AM Thread Starter
Radiator fan clutch
Where is a good place to get one from and what price should i expect to pay??
93 F250 7.3L IDI Turbo XL 149K on the clock
with 4" straight pipe, and goose neck hitch. Pretty much stock, needs 4x4 implant though. An interesting drive in the snow to say the least!
might stand for "Fix Or Repair Daily", but that's what I like doing, fixing things, mostly my vehicles.
Kiwi is offline
post #2 of 9 (permalink) Old 05-01-2010, 10:40 AM
fergy94f250's Avatar
personally im concidering going to an electric fan on a switch free up some power so it dose not have as many accs to run off the belts then my motor can heat up a bit more in the winter and keep it cool in the summer
94 F250 5 speed 7.3 IDI turbo 4x4 ext cab long box
fergy94f250 is offline
post #3 of 9 (permalink) Old 05-01-2010, 01:55 PM
I did my fan clutch a few years back. I think it ran about $90 if I remember correctly. I got it mail order with the radiator.
I have read on here numerous times that electric fans do not work well with these trucks simply because they don't pull mover enough air.
1992 F250 S/C XLT
7.3L IDI, 5 SPD
321,000 miles
Bought it brand new in 1992. Fisher-Vincent Ford in Belton, TX
Burdizzo is offline
post #4 of 9 (permalink) Old 05-01-2010, 04:42 PM
NH2112's Avatar
Not to mention that moving a given volume of air v per minute takes x horsepower, regardless of whether the fan is driven mechanically or electrically.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #5 of 9 (permalink) Old 05-01-2010, 04:48 PM
Snotzalot's Avatar
My Photos: (5)
Auto Parts store about $150.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #6 of 9 (permalink) Old 05-02-2010, 09:43 AM Thread Starter
Thanks guys, I agree that it doesnt matter how you do it, electric or mechanical if you need 3 hp to move the right amount of air you need 3 hp to move that air either 3 hp off the crank or 3 off the batteries (through the alternator) its all the same. Something that I remember from school. Plus i dont need more HPs got enough for what Im doing.
Kiwi is offline
post #7 of 9 (permalink) Old 05-05-2010, 07:05 PM
This is a good place to get one... and I've heard that they are very knowledgeable on fan clutches.. MS Tech
1992 F350 7.3 Liter IDI Four door long bed 4x4 5 Speed Manual ZF. Future: ATS Turbo, John Deere green paint job, gear vendor overdrive kit, Herculiner for the bed, and WVO fuel kit. Also
1990 F250 7.3 Liter IDI two door supercab with 5 Speed Manual ZF planning to sell after I pull my cd player, CB radio, and slider back glass out.
George_7.3IDI is offline
post #8 of 9 (permalink) Old 05-06-2010, 08:10 AM
drcliff's Avatar
Hayden 2833, $138 from rockauto.com.
1989 F350 7.3 IDI C6 DRW 161" W/B
drcliff is offline
post #9 of 9 (permalink) Old 05-06-2010, 08:37 AM
drinkypoo's Avatar
My Photos: (25)
3 hp = 2.23709961 kilowatts. 95A*12V=1140W peak (probably on a 65% duty cycle.) Typical fan draw is closer to 114 watts than 1140.
Just had to be pedantic...
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
