Rear Brakes Hold Down Spring Tool - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By chuckster57
post #1 of 11 (permalink) Old 06-19-2010, 04:44 AM Thread Starter
Snotzalot's Avatar
My Photos: (5)
The hold down springs on the rear shoes can be a challenge to reinstall without the correct tool. A hammer handle works IF you are under 50!
SnapOn offers a hold down brake spring tool for the F&E350's and does a few other companies.
You folks that have such a tool, which one do you own and how well does it work.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #2 of 11 (permalink) Old 06-19-2010, 09:30 AM
My Photos: (27)
Got to have these for the hold-down springs:
And these for the return springs:
LMJD is offline
post #3 of 11 (permalink) Old 06-19-2010, 09:38 AM
chuckster57's Avatar
I have a complete set from Harbor freight that includes the tools shown above plus some others ( spoons, etc) But I usually resort to a pair of regular pliers for the shoe hold down springs.
oldrebuiltdodge likes this.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 11 (permalink) Old 06-19-2010, 10:45 AM
drinkypoo's Avatar
My Photos: (25)
Lineman's Pliers are the best tool I've got for this job, and I have the thing with the plastic handle, too. Sometimes I reach in with long-nosed pliers to press on the retainer directly
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #5 of 11 (permalink) Old 06-23-2010, 09:55 AM
My Photos: (5)
I just worked on my '84 rabbits rear drum brakes last night. I have never used a spring tool on the hold down springs of other vehicles. After 45 minutes of trying, and almost throwing the hammer out the window, I gave up. I tried every method I could think of, multiple pliers/vice grips, and nothing worked.
Spent the $5 on the way home and picked up the tool from Advance Auto. 45 seconds this morning, and the springs are on. In this case, the right tool did the job.
The VW springs are almost completely compressed when on, so no extra room to install them. Big truck springs are much easier. (like on my 1995 F250)
Michael
1995 F250 4x4 Supercab PS
artificer is offline
post #6 of 11 (permalink) Old 06-23-2010, 11:17 AM
johnboggs21's Avatar
I used a combination of a wide flathead screwdriver, and some needlenose pliers. Had mine on in a few minutes.......
1993 F-250HD 7.3L IDI E4OD 370,000 miles Now sporting a strait pipe and has the soup bowl mod.
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
johnboggs21 is offline
post #7 of 11 (permalink) Old 06-23-2010, 11:38 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
I took a pair of lineman pliers, held them closed and drilled a hole near the tip (slightly bigger than spring) about 3/4 the way thru. Works awesome...no injuries anymore!
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #8 of 11 (permalink) Old 06-23-2010, 12:30 PM Thread Starter
Snotzalot's Avatar
My Photos: (5)
This tool won't work on the rear F's and E's.
This is what is needed.
Vehicle Service, Wheel & Brake, Brake Spring Tools & Pliers | Matco Tools Online Tool Catalog
Regards,
post #9 of 11 (permalink) Old 09-17-2018, 07:01 AM
How do you use the matco tool? Amazon has a much cheaper version - Vim Tools B10 Truck Brake Spring Tool.
ziegler is offline
post #10 of 11 (permalink) Old 09-17-2018, 09:10 AM
Steve83's Avatar
Amazon also explains how it's used, right there in the bullets at the top of the page.
Steve83 is offline
post #11 of 11 (permalink) Old 09-17-2018, 11:55 AM
I figured you hooked both ends and the tool would allow you to cross/hook them, guess not. Inserting it into the working end of the spring doesn't extend it so the 2 can cross?
ziegler is offline
