Rear Brakes Problem - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-01-2018, 10:55 PM Thread Starter
Rear Brakes Problem
I can adjust my rear drum brakes and by the end of the week the passenger side will skid the tire and the other side won't. The driver side brakes are always weaker for some reason. Any ideas on this one?
94 F350 7.3 IDI Turbodiesel 4x2 CC E4OD transmission, 4.10 gear ratio, 10.25 ring gear, limited slip, single rear wheels, long bed, Tru-Cool Max 45k transmission cooler l
Hoko is offline
post #2 of 4 (permalink) Old 05-02-2018, 09:57 AM
My Photos: (27)
Probably the self adjusting linkage, star wheel, or whatever is hooked up backwards.
LMJD is offline
post #3 of 4 (permalink) Old 05-02-2018, 11:33 AM
klhansen's Avatar
My Photos: (180)
Or there's a leak at the wheel bearing that has soaked the shoes with oil. That will cause them to grab.
I'd recommend pulling both drums to check it out.
), AIS,
regulated return,
klhansen is offline
post #4 of 4 (permalink) Old 05-02-2018, 03:18 PM
Mammoth73's Avatar
Definitely pull the drums and look for anything that stands out. Make sure if you do decide to take them apart you only take one side apart at a time so you have somethin to go off of.
Also inspect the brake lines up from the master cylinder to each wheel. I once had the same problem on my dodge and it turned out a line got crimped on my back driver side caused by a downed tree on one of my off road ventures.
Sent from my SM-G930V using Tapatalk
Mammoth73 is offline
