slow crank - Diesel Forum - TheDieselStop.com
post #1 of 27 (permalink) Old 01-31-2013, 05:00 PM Thread Starter
tanbuddy's Avatar
slow crank
The alst few days my truck has been cranking very slowly. At work i need a jump to get home so i figured it was the batteries. I had them checked and they were good. I put different good batteries in anyway and the truck is the same.
Im guessing this has to be the starter? Is there anything else that would cause this condition, especially in my garage which is 50 degrese right now?
Are the starters at advanced auto any good?
Work truck: 90 Pete 379, cat 3406B turned up
personal: Late 92 f 250 xlt ext cab 7.3 idi 4x4 5 speed(converted to f 350)
tanbuddy is offline
post #2 of 27 (permalink) Old 01-31-2013, 06:23 PM
Snotzalot's Avatar
My Photos: (5)
A friend who used work at Advance suggests NEVER to buy an Advance starter or alternator,
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #3 of 27 (permalink) Old 01-31-2013, 07:04 PM
wheatie's Avatar
How are your cables? Pos. and Neg.
94 IDI Turbo 5 SPD Crew Cab 4X4, 303K, 295/75/16 BFG's, Big ARSS Stereo. (SOLD)
2006 F250 CC SB Lariet V-10
2003 Excursion E.B. V-10,
2018 Escape Titanium
2005 ZX4 ST Focus
2004 Escape
2012 Escape Limited
wheatie is offline
post #4 of 27 (permalink) Old 01-31-2013, 07:05 PM
check your battery leads and the starter solenoid on the fender if the tip burnt up inside not enough power will get through and cause a slow start speed issue.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
post #5 of 27 (permalink) Old 01-31-2013, 08:58 PM Thread Starter
tanbuddy's Avatar
the cables looked good when i took everything apart. No corrosion or anything like that to speak of. Does the current that goes to the starter flow through the solenoid on the fender? I thought it went right from the battery to the solenoid on the starter.
tanbuddy is offline
post #6 of 27 (permalink) Old 01-31-2013, 09:14 PM
drinkypoo's Avatar
My Photos: (25)
my cables looked good but were corroded internally. had the same problem, replaced them, now there's no problem.
the current that goes to the starter does not go through the solenoid relay on the fender. if you have a stock starter that relay operates the starter solenoid. if you have a nippondenso starter (the stock starter is all inline, the nippondenso isn't) that relay operates the internal relay that operates the solenoid, but the results are the same.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #7 of 27 (permalink) Old 02-01-2013, 10:24 AM
If you have a good volt meter you can trouble shoot somewhat. Since you have good batteries take the voltage with the ignition on and not cranking. Then using the solenoid on the fender crank the engine. If your starter is bad you will drop about 5 to 6 volts from what it was without cranking. If it is your cables the voltage will not drop as much as the current is not reaching your starter. What type of starter is currently on it, the Delco starters seem to slow way down when getting a little worn.
Alvin Mitchell
Pablo Montana
1983 F250 4X4 4.10 gears 4 speed dana 50 center/44 outers Dana 70 rear
Mitchalvin is offline
post #8 of 27 (permalink) Old 02-01-2013, 10:37 AM
drinkypoo's Avatar
My Photos: (25)
What you really want to do is read the voltage drop across the suspect part while cranking. If you read voltage across a resistor in a live circuit you get a reading that will tell you what the effective resistance is at that voltage. So read from one end of a suspect cable to the other, etc.
post #9 of 27 (permalink) Old 02-01-2013, 12:09 PM
nbkr341's Avatar
You couldn't pay me to put an advance/autozone/oreilleys/etc part on my truck. Just about every one I've had has failed within the year.
93 Ford F250 7.3 IDI
2wd
E4OD Auto
31" bfg all terrains
Just rolled 100k original miles
nbkr341 is offline
post #10 of 27 (permalink) Old 02-01-2013, 02:35 PM
drinkypoo's Avatar
My Photos: (25)
thing is, that's just what I say about Napa, so who's left?
Answer of course is to order online, but sometimes you need something right away...
post #11 of 27 (permalink) Old 02-01-2013, 03:35 PM Thread Starter
tanbuddy's Avatar
Im not sure which starter is on there now, im gonna pull it off and look at it. I was thinking of getting this one rebuilt, s&w starter and alterantor isnt too far from here eather.
Will one from an auto truck work in a stick application? I found a used factory one but its from a auto for 50 bucks. I dont know if thats agood deal or not eather
tanbuddy is offline
post #12 of 27 (permalink) Old 02-01-2013, 04:26 PM Thread Starter
tanbuddy's Avatar
pulled it, the starter has a mitsu*****i symbol on it and it says made in japan. I believe that is the stock unit. I hooked up my battery to the starter on the workbench, and it turned over, but it took about 5 seconds to get up to speed, it didnt jump to speed all at once. Im gonna get this tested and see what happens from htere.
tanbuddy is offline
post #13 of 27 (permalink) Old 02-01-2013, 05:15 PM
I have not had good luck with NAPA rebuilds, I usually replace the item multiple times in the first month. I had one alternator that had to be specially ordered and had 3 separate bad ones in a row, no charge out of the box. The last starter I replaced once with a rebuilt and then bought a new one because of the location and difficulty in replacement. A new Mitsu or Ndenso costs more but will save in replacement labor over a rebuilt. Most Mitsu or Ndenso do not get rebuilt because by the time they stop working the armature is so fried it has to be rewound or will not work.
Alvin Mitchell
Pablo Montana
post #14 of 27 (permalink) Old 02-01-2013, 07:16 PM
My Photos: (27)
Your best bet is take it into a local auto electric shop and have it rebuilt. The brush wires are spot welded rather than screwed on so it's not a home job. A complete overhaul with top quality AMERICAN parts cost me $104 a couple years ago. Can't hardly beat the Mitsubishi, mine lasted 19 years and 240,000 miles before needing a rebuild.
LMJD is offline
post #15 of 27 (permalink) Old 02-02-2013, 06:00 PM Thread Starter
tanbuddy's Avatar
I had it tested, the guy said it was shorted internally and it popped his breaker. 150 for a rebuild w/1 year warrenty. Lifetime warrenty from napa is 139, if they were more reliable it would be a easy choice.
tanbuddy is offline
