Smoke Issues - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-06-2013, 09:08 PM Thread Starter
Smoke Issues
Hey ya'll just bought a 89 f250 with the 7.3 idi about a month ago. had nothin but issues since i got it. also this is the first diesel i've ever owned or worked on...
First off when i brought it back i changed out the oil. turns out there were only 3 qts in the pan. the guy i bought it from said the "water in fuel" light has been on since he bought it but turns out there was a lot of contaminated fuel in the tanks as well as water. (the fuel filter that WAS on it had no water seperator either.
I took it in the shop about 3 weeks ago because it was havin this real bad smokin issue. (billowing clouds of white smoke, especially from a cold start. but continued after warmed up and drove) I had bad injectors so i had those replaced as well as had them rebuild the injector pump.
Got the truck back and wouldn't ya know it about a day later I had the same amount of smoke comin out the pipes. So my question is.... what's up with the smoke? I dont wanna take it back to the shop since i just dropped them 1500. this smoke have something to do with bad components down in the pistons or something?
Also while I'm posting, yesterday I was drivin from a light. pushed the clutch to switch to 3rd and the clutch pedal stuck on the floor. now it just wobbles back and forth. i know its got somethin wrong with the hydraulics but i dont really know where to start checking. just the hydraulic line from the tranny to see if theres leaks? should i purge it first? (and how do i purge the hyd line) or you reckon i should just replace the hyd master cylinder?
Any advice on both these issues would be great. If anyone wants to tell me to ditch it and get a powerstroke go ahead. i wish i could now.
Thanks again,
Josh
jdurham is offline
post #2 of 3 (permalink) Old 02-06-2013, 09:27 PM
have a gander up under the dash and make sure everything is still connected the master may be shot but usually there is a spring that will over center and either pull it back to top or hold it to the floor, the slave cyl is more likely to fail
92F250-7.3GUY is offline
post #3 of 3 (permalink) Old 02-07-2013, 10:32 PM Thread Starter
preciate the reply 92F250-7.3GUY. got the clutch fixed today. that push rod lookin thing worked its way out of the master cylinder.. got it replaced.
anyone know anything about the smoke??
jdurham is offline
