Steering Column Slop Removal - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By geezer88
post #1 of 4 (permalink) Old 05-11-2019, 10:36 AM Thread Starter
I've got an '88 F250 4x4 diesel that isn't worth putting a lot of money into, but the slop in the steering column sliding joint was driving me nuts. I found I could slip an .018" feeler gauge into the joint, so I got to thinking of ways to keep a shim in place. I found an old clock spring that was .250" x .020" in cross section. It is good hard steel, so I cut two pieces, each four inches long. I pushed them as far as possible into the gap. The flat on the inner shaft is just a little wider than .500", so the two strips fit well. To keep them in place, I bent them back over the outer shaft and held them in place with a hose clamp. See picture. Only driven it a few miles so far, but it feels so much better not having to work so hard keeping it between the fence posts. tom
morgankshaw likes this.
1988 F250 7.3 idi 3/4ton 4x4
geezer88 is offline
post #2 of 4 (permalink) Old 05-11-2019, 10:41 AM Thread Starter
Sorry about the inch symbol being interpreted as "quote". tom
geezer88 is offline
post #3 of 4 (permalink) Old 05-11-2019, 10:51 AM
Man thatís a great idea. I have replaced almost everything in my steering and thereís still that bit of loose play. I bet itís in the slip joint! Iím gonna check it out!
morgankshaw is offline
post #4 of 4 (permalink) Old 05-11-2019, 11:55 AM
Steve83's Avatar
It's very easy to remove the intermediate steering shaft, pull it apart, and fix the plastic retainer or spring steel clip inside. It's also easy to find them in good condition in junkyards and just swap them out.
(phone app link)
(phone app link)
Steve83 is offline
Similar Threads
Steering Column Replacement in 97' Ford SuperCab 7.3L Sethro123 Power Strokes 1994-1997 General 6 01-21-2012 09:12 AM
Steering column????? GreasyPalm Power Strokes 1994-1997 General 2 08-28-2011 07:25 PM
Have a parts steering column or turn signal switch? mbmitche 6.9L IDI Diesels (Not Power Strokes) 4 09-14-2006 08:11 PM
Have a parts steering column or turn signal switch? mbmitche 7.3L IDI Diesels (Not Power Strokes) 3 08-30-2006 08:39 PM
Power Steering Pump Removal DaveBey Power Strokes 1994-1997 General 2 06-18-2006 12:40 PM
