Wad of wires connected by a screw cap next to my turbo?? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 10-28-2015, 07:10 PM Thread Starter
94turbodincamo's Avatar
Ok bought this truck in an attempt to kind of restore it . Well one eye sore is a set of wires connected to what looks like a selenoid or something right next to the turbo on the passenger side. What is this thing
94turbodincamo is offline
post #2 of 14 (permalink) Old 10-28-2015, 07:38 PM
chuckster57's Avatar
Glow plug controller. In the turbo engine it sits on the passenger side valve cover.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 14 (permalink) Old 10-28-2015, 10:15 PM Thread Starter
Ok if this is not wired correctly could it cause throttle issues and it to die randomly?
post #4 of 14 (permalink) Old 10-28-2015, 10:48 PM
No. Its sole purpose is to energize the glow plugs for easier starting.
Train Horns:
post #5 of 14 (permalink) Old 10-29-2015, 12:12 PM
Steve83's Avatar
Any of these could cause random electronic & driveability faults. Click them & read the captions:
This explains how to post pics free almost anywhere:
How do I post pictures, sounds, and or videos? | SuperMotors.net Forums | SuperMotors.net
Steve83 is offline
post #6 of 14 (permalink) Old 10-29-2015, 12:41 PM
The IDI engine is totally mechanical. There are no sensors or any electronic controls. The only "electrical" part needed to keep an IDI engine running is 12VDC to the FSS.
I suppose if the Alternator failed, then sometime later the voltage to the FSS would drop enough to shut off the fuel.
Train Horns:
post #7 of 14 (permalink) Old 10-29-2015, 01:41 PM
Bill1013's Avatar
Put your truck in your signature.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #8 of 14 (permalink) Old 10-29-2015, 06:42 PM
Steve83's Avatar
The caption of this diagram explains how to collect most of the relevant info:
Steve83 is offline
post #9 of 14 (permalink) Old 10-29-2015, 10:25 PM Thread Starter
Ok still trying to diagnose my problem. Taking the shader valve out now where should I get /what kind of psi gauge should I put in its place to check the psi
post #10 of 14 (permalink) Old 10-29-2015, 10:31 PM Thread Starter
It's a 94 7.3 Idi
post #11 of 14 (permalink) Old 10-29-2015, 10:37 PM
Any fuel pressure gauge will work. It only needs to read up to 10 PSI. I have (had until someone needed it more than me) a set from Harbor Freight I think it was like $25.00
With the schrader core out just hook the pressure hose to that fitting.
Train Horns:
post #12 of 14 (permalink) Old 10-30-2015, 04:48 PM
Steve83's Avatar
You don't need to core the valve - just screw the gauge's hose onto the fitting.
Steve83 is offline
post #13 of 14 (permalink) Old 10-30-2015, 05:55 PM
If you can't get to a Harbor freight, get a 1/8" NPT back mount gauge 0-30 psi. Screw the schrader valve out of it's socket, and put the gauge in its place. You might want to put a needle valve between the gauge and the filter housing, to take the shake out of the gauge needle, so you can read it. It'll cost about 30 bucks if you get the good stuff.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #14 of 14 (permalink) Old 10-30-2015, 06:40 PM
That works if the hose has the proper end fitting. With the core out you can also do the volume test.
Train Horns:
