What is this code? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 04-27-2019, 05:30 PM Thread Starter
What is this code?
My brakes power assist is not working, push hard, brakes little. I pulled a code with my test light since a code reader does not work. The code was 4 sets of 9 flashes. 9999 What is this code?
94 F350 7.3 IDI Turbodiesel 4x2 CC E4OD transmission, 4.10 gear ratio, 10.25 ring gear, limited slip, single rear wheels, long bed, Tru-Cool Max 45k transmission cooler l
Hoko is offline
post #2 of 11 (permalink) Old 04-28-2019, 07:00 AM
ford_doctor's Avatar
The flash-out code format repeats the code 4 times so your code is 9, not 9999. Code 9 means high resistance in the rear wheel speed sensor/circuits on the rear axle. This would have nothing to do with your lack of power assist though. Just to verify what you have, is this a vacuum or Hydro-Boost system?
Originally Posted by Ford Motor Company
9.4 CHECK FOR OPEN SENSOR
Verify ohmmeter is on 20K ohm scale.
Measure resistance between RABS sensor Pins A and B.
Is resistance less than 2500 ohms?
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 11 (permalink) Old 04-28-2019, 07:29 AM Thread Starter
I don't know. How can I tell? I do have a pump looking thing that the belt runs that sits right next to the oil fill spout that has a hose that connects to the vacuum manifold from which a hose runs to the power booster. I did check the hose that connects to the power booster yesterday for vacuum with my finger. The vacuum was almost not detectable but there was a slight vacuum. I don't know how much vacuum is needed.
Hoko is offline
post #4 of 11 (permalink) Old 04-28-2019, 07:51 AM Thread Starter
I am not familiar with those terms. I don't know.
Hoko is offline
post #5 of 11 (permalink) Old 04-28-2019, 08:00 AM
A Hydro-Boost system uses power steering fluid as a booster which was commonly found on F350/450 dual rear wheel applications but there were some weird ones that had it. I was pretty sure your truck has a vacuum booster but we don't want to assume. Your truck should have a low vacuum sensor connected somewhere between the pump and the vacuum booster... cant always be sure it has not been removed or is non-functioning. For your lack of power brake assist make a visual inspection for leaks and obvious damage. Next step would be to verify vacuum which should be in the 18" to 22" range. If present and working, the low vacuum warning switch should turn on the red brake warning indicator on the instrument cluster when vacuum drops below 10" for more than 7 seconds.
post #6 of 11 (permalink) Old 04-28-2019, 08:59 AM Thread Starter
Yes, that light was on yesterday.
Hoko is offline
post #7 of 11 (permalink) Old 04-28-2019, 09:12 PM
bugman's Avatar
My Photos: (12)
I would say that your vacuum pump is shot. Either that or you have a massive vacuum leak.
bugman is offline
post #8 of 11 (permalink) Old 04-29-2019, 12:08 AM Thread Starter
You are right. After I disconnected the pump hose from the vacuum manifold and ran it directly to the booster, it worked fine. What else hooks into the vacuum on these trucks?
Hoko is offline
post #9 of 11 (permalink) Old 04-29-2019, 06:26 AM
Follow the main hose from the vacuum pump, on the driver's side fender well there is a manifold/check valve check the manifold for leaks, and also, look at the check valve to see if it works. From there, look at all of the lines running from the manifold, check for leaks.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #10 of 11 (permalink) Old 05-01-2019, 10:31 AM
Steve83's Avatar
RABS/RABS-II code list:
(phone app link)
Read the PREVious & NEXT several captions for more info.
Vacuum booster function:
(phone app link)
Hydroboost function:
(phone app link)
Steve83 is offline
post #11 of 11 (permalink) Old 05-07-2019, 11:15 PM Thread Starter
Turns out, the hose from the vacuum pump to the manifold had a hole in it. Replaced it and the vacuum is excellent.
Hoko is offline
Similar Threads
Speedometer; Tire conversion constant? dieseldude73 E-Series Vans 6 12-19-2015 01:38 AM
Help with P0299 code after ATS Aurora 3000 install hancoc Upgrades and Aftermarket - 6.0L Engine 1 06-05-2011 06:25 PM
How many of you with NO mods have had problems? traildog 6.0L Power Stroke Engine and Drivetrain 118 05-27-2010 07:45 PM
Keyless Entry Factory Code Not Working obonaventure 1999-2007 General Questions 11 09-21-2005 07:43 AM
