What did you do to your IDI today? - Page 9 - Diesel Forum - TheDieselStop.com
post #121 of 2032 (permalink) Old 05-19-2010, 02:07 AM
88beast's Avatar
fixed my volt gauge and wanted to do more but my hurt knee said no then i got conned into replacing a ps line on a yoda
but i painted some on my motor project and on it i pulled one valve stem seal to see how good it was
welll it was so brittle it broke without any real pressure
88 f250 96 bed 95 front clip western mirrors and big ole bumper.
7.3 idi t70, 3g, g31,
other mods, oba, warn winch, big steel goodies including a headache rack etc.
check out my site at
88beast is offline
post #122 of 2032 (permalink) Old 05-19-2010, 07:50 AM
drinkypoo's Avatar
My Photos: (25)
Re-plumbed the CDR into my custom intake; the CDR sticks right into the rubber seal in the valve cover now, and a pipe runs from the output. Hoping to get more drain-back this way.
Added some little plastic clips to the inside of the door to stop rattlin'
Added a quart of trans fluid, I still have a leak somewhere.
Bought a throttle return spring 'cause the pusher spring plasticrap died and my puller spring is garbage
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #123 of 2032 (permalink) Old 05-19-2010, 07:39 PM Thread Starter
clgielin's Avatar
- drinkypoo
could you post a few pics of your intake?
clgielin is offline
post #124 of 2032 (permalink) Old 05-19-2010, 09:57 PM
fergy94f250's Avatar
took it for a good drive to find parts but then relized left my money at home so i couldn't but the parts i wanted oh well sooner or later.
any one know how to turn up the injection pump she is running a little lean
94 F250 5 speed 7.3 IDI turbo 4x4 ext cab long box
fergy94f250 is offline
post #125 of 2032 (permalink) Old 05-19-2010, 10:37 PM
chuckster57's Avatar
Are you sure it's lean? what are the symptoms? anyway here is the article,READ AND HEED warning about pyrometer:
"Fuel injection pump adjustment article"
Train Horns:
PM please not visitor message
chuckster57 is offline
post #126 of 2032 (permalink) Old 05-20-2010, 12:05 AM
NH2112's Avatar
Diesels run "lean," or with a high air:fuel ratio, all the time. It's when they're running "rich" that you have problems like melted pistons & valves if you don't let off the accelerator or downshift to get some airflow.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #127 of 2032 (permalink) Old 05-20-2010, 01:24 AM
Painted the heads lime green!
7.3_idi is offline
post #128 of 2032 (permalink) Old 05-20-2010, 01:00 PM
well it seemed to fix it self it is running really good now it feel like it didn't have the power to get up and go so i was wondering if i through some more fuel in it it might run better but she is running really good today so im not sure what the problem is but i know my temp gauge is acting up and my oil pressure gauge is not working i have been looking at oil pressure gauges but i need to know dose it come with all the fittings to tie into the orignal sending unit i have noticed that the wire going to the orinal sending unit is loose on the connection so im thinking if i clam the connector a little it might get a proper reading of the sending unit any idea how to fix this promblem
post #129 of 2032 (permalink) Old 05-20-2010, 01:29 PM
A bad batch of fuel will make my IDI run different. Yeah if you get the right gauge it will come with all the fittings/wiring or lines to make it work.
Train Horns:
post #130 of 2032 (permalink) Old 05-20-2010, 11:31 PM
what would be the right gauge/who makes the right gauge ??????
post #131 of 2032 (permalink) Old 05-21-2010, 12:03 AM
NH2112's Avatar
Just go to NAPA, Autozone, etc, and get a gauge kit with a 0-80psi or 0-100psi gauge, mounting bracket, sender & adapter bushings, and wiring.
Phil
NH2112 is offline
post #132 of 2032 (permalink) Old 05-21-2010, 12:37 AM
88beast's Avatar
put my pyro in it works good it took 4 hrs of hassel to do it though almost pushed the truck in the pond but i knew the pond wasnt deep enough to do damage
88beast is offline
post #133 of 2032 (permalink) Old 05-21-2010, 08:06 AM
drinkypoo's Avatar
My Photos: (25)
Originally Posted by clgielin View Post
- drinkypoo
OK: Custom F250 Turbo Diesel intake | hyperlogos.org
I still need to do something else about the CDR, it doesn't stay well. Cutting down my hose might work.
post #134 of 2032 (permalink) Old 05-21-2010, 10:01 AM
88beast's Avatar
use a catch can for the cdr
88beast is offline
post #135 of 2032 (permalink) Old 05-21-2010, 10:29 AM
drinkypoo's Avatar
My Photos: (25)
I'd rather do an oil sep. Do powerstrokes have CDR?
Closed Thread
