What filter for add-on tranny filter? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 05-16-2017, 02:27 AM Thread Starter
I bought a used external/remote oil filter setup pretty cheap. I am expecting to use it for a tranny filter. I am wondering what filter element number I should look for that is used in this application?
Also, I need to expand my understanding. I am thinking that the filter will not be above the tranny so I won't need an anti-backflow filter.
I am wondering if I should have a by-pass valve in the filter. I dunno if it would work in an emergency or not.
I was given a ton of Amsoil synthetic AT fluid, maybe $500 worth. The stuff worked a charm in my truck's 5-spd manual tranny when it got hot (I used new stuff in there), now I want to use it in my RV E4OD. The fluid has sat out and was exposed to blowing dust and maybe sand, maybe some water. It looks pretty good but I won't simply dump it into my tranny. I am wonder if I could fix it up by using my new filter kit to rig up a manual method of filtering it. Any ideas about this? Is it a stupid idea? I'm guessing for this I would want a filter w/o an anti-backflow valve since I expect to use gravity to feed the filter. Or not, I dunno yet. Maybe I'll strap it to a merry-go-round and centrifuge it.
1992 E350 RV, 7.3L IDI, E4OD, Dana 70 HD, 4.10, duals, 40k miles
1990 F250 7.3L IDI, ZF 5-spd, 3.55, 4x4, long-bed x-cab 130k
gab16 is offline
post #2 of 13 (permalink) Old 05-16-2017, 12:07 PM
I sure would be wiry using ATF that's been exposed to sand, dust and water. You would have to use a 2 Micron filter element, then run it thru 5-6 times. Better use is to use it for campground fire starting, it'll burn but not to good.
E4OD rebuilds is expensive, $2100 and up.
92 F350 Lariat, 2WD, Dualie, CC, LB, E4OD Trans, Banks Sidewinder turbo, GV O/U, Pyro, Boost, Oil temp, Trans temp. Chassis 129K, Engine 7.3L 75K. Bench seat.
"99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
ScanGaugeII SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
IDI firing order 12734568--------1&4-2&5-7&6-3&8 Cyl's @ TDC. 1&4 TDC when timing mark is @ 0. Each 1/4 turn, next 2.
Trucker87 is offline
post #3 of 13 (permalink) Old 05-17-2017, 08:00 AM
My Photos: (27)
Yep, might be real expensive trans fluid in the end.
LMJD is offline
post #4 of 13 (permalink) Old 05-18-2017, 03:33 AM Thread Starter
if I find I cannot get it clean I'll do something else with it. I am a cautious person.
gab16 is offline
post #5 of 13 (permalink) Old 05-18-2017, 04:45 PM
To remove water, heat it to about 200*F, and hold it there until the steam stops. Then filter it carefully, and mix it 2:1 diesel fuel then dispose of it in the fuel tanks. You then would do less damage to your truck than if you used it in the tanny.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #6 of 13 (permalink) Old 05-19-2017, 08:35 AM
Save up for a new/rebuilt IP if using it for fuel.
post #7 of 13 (permalink) Old 05-19-2017, 05:58 PM
Be about the same as priming the filter with tranny fluid. as lightly as it would be mixed.
post #8 of 13 (permalink) Old 05-20-2017, 09:08 AM
It's not the fact that it won't burn. But eventually the dirty ATF will wear out the IP. It's a proven fact that even using WVO and WMO will shorten the life and maybe make an IP un-rebuildable. Without a very good centrifuge and filtering system I would never use it myself.
post #9 of 13 (permalink) Old 05-20-2017, 09:23 AM
Relentless007's Avatar
Using that ATF fluid is a terrible idea. The E40D is already a fickle beast as it is, why tempt fate over $95 ? Your tow bill would be higher than that, much less the rebuild.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #10 of 13 (permalink) Old 05-20-2017, 09:50 AM
My Photos: (27)
Right, looking clean to the naked eye and being 100% clean are two different things. And as posted, I sure wouldn't used it in my fuel tank either.
LMJD is offline
post #11 of 13 (permalink) Old 05-23-2017, 01:20 PM
Steve83's Avatar
Dispose of the old ATF properly. Buy new MotorCraft MerconV fluid, and put a Magnefine filter in the cooler line behind the radiator where it's easily-accessible from below:
Steve83 is offline
post #12 of 13 (permalink) Old 05-23-2017, 06:49 PM
x2 on the magnafine
BTS Valve Body
Tymar Air Intake
post #13 of 13 (permalink) Old 05-23-2017, 11:52 PM Thread Starter
Thanks!
gab16 is offline
