1986 F250 will not idle - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 04-02-2019, 09:39 PM Thread Starter
Ok, I've got the truck to start and run for 10 to 15 seconds then it dies but the idle is really low. I've put the clear line on the return line checking for air intrusion and there is no sign of air coming back to the T at the injector feed line. I've bled the filter to see if air is coming out of the schrader valve and it is good. I also pulled the check valve at the top of the injector pump to see if it was plugged and not sending fuel back. It was clean and the little clear ball was easy to move. So I am perplexed. Please let me know what you think ASAP, I need to get her going again.
Kielly is offline
Similar Threads
02 f250 skip at idle but runs out good bd111503 '99 & up 7.3L Power Stroke Engine and Drivetrain 2 06-12-2014 04:26 PM
96 f250 long start, rough idle, slight surge, catskillfire51 Power Strokes 1994-1997 General 3 09-22-2013 08:31 PM
1987 vs 1986 Ford F250 IDI NoSmog97 6.9L IDI Diesels (Not Power Strokes) 9 09-03-2013 07:53 AM
1986 F250 flat bed size? Hiball76 6.9L IDI Diesels (Not Power Strokes) 1 07-30-2013 11:05 AM
New member/new used 1986 f250 6.9 slammin salmon 6.9L IDI Diesels (Not Power Strokes) 2 05-25-2010 06:55 PM
