heater problems and it's -27F - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 11-23-2010, 11:36 PM Thread Starter
hougie's Avatar
My Photos: (11)
Exclamation heater problems and it's -27F
The ol heater seems to blow hot but it doesn't blow hard at all. Fan sounds like it's running fast and blowing hard but it's really not blowing much at all. I searched heater and ran through last 5 years of posts and found nothing
2004 CREW CAB PSD, no mods, 305/70/16R wrangler MTR.
1985 ford f-250 4x4 6.9l sc "the beast"
4" lift, 35" toyo mud terrain's, Ip turned up, stacks
hougie is offline
post #2 of 9 (permalink) Old 11-24-2010, 07:44 AM
vegoildieselguy's Avatar
When i took my blower fan assembly out there was alot of junk in the little compartment that the fan went in. I don't know if that would be the problem.
1985 Ford F-250 w/ freshly rebuilt 6.9 diesel, reg. cab, 2WD, zf-5, 10.25 rear, short throw exhaust 2.5" down pipe to 5" to 7" tip, Banks non wastegated turbo, Isspro pyro, Isspro Tach., custom flatbed 9' long x 7 1/2' wide, 3g alternator, push button gp's, memphis audio sound w/ kenwood stereo and amp, Toredor Red and Cream white. Practically restored. 6500lbs
vegoildieselguy is offline
post #3 of 9 (permalink) Old 11-24-2010, 09:18 AM
1987IDI's Avatar
My Photos: (14)
Mine also was full of leaves and sticks and junk. Open the hood, remove the fan, reach your hand in there and scoop out all the junk. it could be blocking incoming air.
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
post #4 of 9 (permalink) Old 11-24-2010, 11:24 AM
Joe Mc's Avatar
My Photos: (39)
The heater-boxes on these trucks collect lots of leaves and other junk that can block airflow and has been known to start fires. After you take the fan out be sure to carefully reach around the corner and get all the junk away from the fan resister-pack, the pack has some sharp corners. I try to pull the fan for a clean-out every year after the leaves drop.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #5 of 9 (permalink) Old 11-24-2010, 06:56 PM
ALSO!!!!! if some previous owner--thru things on top of the dash--and some fell down into the heater box--and then traveled, to the blend door--oh boy!!!!!! s the hinge pin, on that door,is plastic, and the vacuum can, has enough power to pull the door,,and break the hinge pin--and the cure??????? pull the dash back a bit--and pull the whole heater box assm, and replace the door!! got a 86 i aint fixed yet--as its a JOB!!!! or just get a whole diff heater box assm,and check the pin in it aint broke!!!!!!! as it seems,,LOTS of people, like to throw things of the top of the dash,,,,,,,smelled smoke,like sulphur in mine one day,,,,smoke out the vents,,seems bozo before me liked to smoke, and a book of matches fell down in there,and when the heater came on for the first time--the heat was hot enough, to light the matches!!!!!!!!!!!!!!!!!!!!!!!!!! they went out after a bit--and still have a melted spot on the outside firewall box!!! luckily it didnt start on fire!!!!!!!!!!!!!!!
94_turbo is offline
post #6 of 9 (permalink) Old 11-24-2010, 06:56 PM
KJGehr's Avatar
i had a car burn one because of a mouse nest in the heater box, blower resistor lit it up
1978 F-350 XLT Super Cab 4X4, srw dana 60's, 17" ford superduty alloy wheels,Stake Body 6.9, finally ZF-5, 4.11 gears. 02 dodge Laramie seats,fact. 80's tach modded into ac vent in dash, push button G/P's Banks turbo set up ready to bolt on w/ 3' stainless full length exhaust, now to rebuild the heads
KJGehr is offline
post #7 of 9 (permalink) Old 11-24-2010, 07:03 PM Thread Starter
hougie's Avatar
My Photos: (11)
i've dropped alot of .22 caliber casings down there but i don't think it's the door. How do i pull the fan apart?
hougie is offline
post #8 of 9 (permalink) Old 11-24-2010, 08:04 PM
Joe Mc's Avatar
My Photos: (39)
If your lucky enough to have a truck with AC, it is simple. Open the hood, see the fan motor on the passenger-side of the firewall, pull the 4 screws an it slides out.
Non-AC are said to be different.
A little more information in your signature, is sometimes helpful.
Joe Mc is offline
post #9 of 9 (permalink) Old 11-24-2010, 10:59 PM Thread Starter
hougie's Avatar
My Photos: (11)
i've got ac
hougie is offline
