Rough starting 1984 F250 6.9L IDI Diesel - Diesel Forum - TheDieselStop.com
post #1 of 39 (permalink) Old 03-25-2016, 10:24 PM Thread Starter
Diesel noob here.
Got a rebuilt 1984 250 6.9, turbo I think? for a work truck, runs great when warmed up, but starting her in the morning is a task.
I'm in Portland,OR and lows are around 40 right now. Have block heater but haven't used it yet, did not seem necessary. I won't always have access to electric in my travels so would like to avoid using when possible.
First few days I started it was very rough, 4-5 tries, had plugs on for 30-60 sec. Lots of white smoke out exhaust. But it eventually turned over and ran very smooth all day. Near instant starts after initial rough morning start
Then I left heater on one night, did not realize it was hard wired and drained battery. Charged batteries, then burned out starter trying to turn her over...not fully charged turns out.
Now I have fresh batteries, new starter and alternator. But only way I can get her going in morning is a squirt of starter fluid.
I hear this is very bad from some and nbd from others.
I wouldn't mind changing glow plugs, but hear that may not be issue. Some say it's the actual electrical housing for plugs...or something else entirely.
Lots of opinions out there, curious to hear more. Would like to fix myself if possible and have a reliable starting truck when I'm out in the country hunting, wandering, what not.
Can provide more info and pics as needed. Thanks for any help!
Jordansaia is offline
post #2 of 39 (permalink) Old 03-25-2016, 10:32 PM
ArcticDriver's Avatar
Welcome to the Forum.
As you have already heard, starter fluid is a very bad idea and the guys who have told you its no big deal should probably be avoided.
When you say the "heater is hard-wired" I am not sure which heater you mean. Do you mean the blower motor for your dashboard heater/vent system? Or your block heater?
A block heater is in no way connected to your batteries. The block heater operates on your homes 120v AC current and all the power onboard your truck relies on the batteries 12v direct current. They are completely independent of each other. There is really no "bad" time to plug in your block heater when the engine is not running as far as your truck is concerned. Your wallet might dictate otherwise but given your decpscription of cold starts I would plug in 2-3 hours before trying to start even at +40*.
I would also inspect/test the GPs and the GPR (Relay) because your description sounds like the classic symptoms for one or both of these needing replacement. You just need an inexpensive multi-meter ($10 at Sears) that can test both Voltages and Resistance (Ohms).
Plugging in the block heater will be a far less costly practice than using starting fluid until you get this sorted out.
Cheers
SOLD:
ArcticDriver is online now
post #3 of 39 (permalink) Old 03-25-2016, 10:45 PM
chuckster57's Avatar
Rough starting 1984 250 6.9 Diesel
If your glow plugs are energized for 30-60 seconds, your burning them out. No longer than 15 seconds is needed. If you do need to do it twice, wait about 30-45 seconds and then another 10-15 seconds should do it.
I would start by changing the glow plugs, make sure you DO NOT use Autolite.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #4 of 39 (permalink) Old 03-25-2016, 11:11 PM Thread Starter
Thanks for the quick reply guys!
The heater that is hard wired is the dash vent. Not sure why it is, but I'd like to resolve that when I get starting issue sorted. The CD player also resets when turning truck on/off. But these are minor issues for now.
I'll start out testing the plugs and relay.
What numbers am I looking for with the resistance and voltage?
Do I need to take out plugs to test?
Where is relay located?
Been looking through videos, but finding lots of different results so far, I prefer the written word anyways
Thanks!
post #5 of 39 (permalink) Old 03-25-2016, 11:13 PM Thread Starter
What brand of plugs do you recommend?
post #6 of 39 (permalink) Old 03-26-2016, 12:26 AM
Quick test is a test light. Clip the Eire lead to the positive post and then use the tip to touch the top of the GP. Light on-GP may be good. No light GP is shot.
Using an Ohm meter from good ground to GP tip should be 2 Ohms if I remember right.
Motorcraft/Beru are the preferred brand. I have a set of DieselRx from thedieselstore.com that have been in since 2008.
Train Horns:
post #7 of 39 (permalink) Old 03-26-2016, 01:03 AM Thread Starter
Thanks for the advice, will post update on how it goes tomorrow
So, if the starting issue does turn out to be plugs or relay and I replace, can I expect good cold starts when I am out in the back country? What other common starting issues could I have?
Want to do my best not to get stuck out there!
post #8 of 39 (permalink) Old 03-26-2016, 01:25 AM
Since your truck runs great once its started then just replacing the GPR and GPs are quite possibly the whole problem. These are common failure parts. Even if just a few of your GPs test "failed" it is pretty common to replace them all. As Chuck mentioned the concensus is to stick with Motorcraft (which are made by Beru if you find that brand).
Once replaced you should not have an issue starting cold in temps at +20*F and maybe even colder as long as your batteries are good and fully charged.
I still don't quite understand what is going on with your dash heater/vent blower remaining powered on after the ignition is off. Can you actually hear and feel the blower still operating? This is not common so don't rule out there could be a different issue killing your batteries. Here again, a multi-meter will allow you to test charging voltage and battery voltage when you shut down for the night and compare it against the following morning. A very important tool for your emergency kit in the back country.
Fun times ahead as you start to read old posts here at TDS and learn more about your rig.
SOLD:
post #9 of 39 (permalink) Old 03-26-2016, 02:13 AM Thread Starter
The previous owner did a rebuild and pulled out the old dash, did a customized flat panel with multiple gauges.... Half of which don't work.
Heater and defrost are running directly from battery I think. I need to manually turn off after use or they drain battery.
Speedo and fuel gauges seem good
Tach gauge is very irratic, think it's reading off alternator, but I havent traced it yet. Did find a very strange device strapped to old alternator. Need to take a pic to describe well. Looks like a 3" strip of metal bent twice at 90 angles, then two wire contacts coming from top and running into main wire housing. Guessing this is the tach device.
Engine hums when warm, feels like good power and response when driving, tranny feels good but I don't know too much about them to closely inspect
Lots of oil leaks, white smoke coming from lower part of block when attempting to start cold with GPs. Smoke goes away after 1-2 minutes of idle.
That's all the obvious stuff I've noticed. Think I'm going to get better versed into hacked electrical systems soon...
post #10 of 39 (permalink) Old 03-26-2016, 02:28 AM Thread Starter
And yes @ArcticDriver to clarify, blower is still running normally after ignition is off
post #11 of 39 (permalink) Old 03-26-2016, 04:57 AM
After your post describing the PO work on custom dash I realized you have a FrankenDash and anything is possible
Good luck !
SOLD:
post #12 of 39 (permalink) Old 03-26-2016, 08:45 AM
Zork's Avatar
Don't use Champion @ $2 either. The Motorcraft/Beru seem to be the best according to what I've heard about reduced swelling and longevity.
The full loathe honey, but to the hungry even what is bitter tastes sweet.
Zork is offline
post #13 of 39 (permalink) Old 03-26-2016, 01:23 PM Thread Starter
Yep def a FrankenDash,glad i got her on the cheap.
So i went to test the glow plugs today and I have no idea where they are. What I thought was them looks like it has injector lines going into top of block. The other candidates have no harness. Picture attached, what am i missing?
post #14 of 39 (permalink) Old 03-26-2016, 03:50 PM
Yeah, you were probably looking at the injectors. I circled them both for you. The glow plug connectors have a little plastic hook on one of the large flat sides you have to squeeze to pull them off.
It wouldn't hurt make sure you have 12V going to each plug too.
1985 6.9L F-250 XLT-Lariat; Ext. Cab, 8ft box, 175k Miles, C6, 2 wheel drive 3.55 Ford 10.25 open.
bobleny is offline
post #15 of 39 (permalink) Old 03-26-2016, 05:25 PM Thread Starter
Thanks will give it a shot.
Also, tried block heater for for 3 hours this morning and no start. Had to use starter fluid again. Any other ideas?
