Rough starting 1984 F250 6.9L IDI Diesel - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 39 (permalink) Old 03-26-2016, 05:18 PM
ArcticDriver's Avatar
Originally Posted by Jordansaia View Post
Thanks will give it a shot.
Also, tried block heater for for 3 hours this morning and no start. Had to use starter fluid again. Any other ideas?
Might not hurt to test the block heater to make sure it is working because your symptoms are classic for a failed GP/GPR.
SOLD:
ArcticDriver is offline
post #17 of 39 (permalink) Old 03-26-2016, 05:30 PM Thread Starter
Jordansaia's Avatar
Tested the 4 easy to access plugs and got no reading at all with test light. Going from positive terminal to tip of glow plug.
What is a good way to test relay with test light? Or should I be using a multimeter?
Looks like a i found a good price on the diesel rx here:
1984 FORD F 250 Diesel Rx Glow Plugs DRX00088 - Free Shipping on Orders Over $99 at Summit Racing
not finding the replacement relay though, any recommendations?
Jordansaia is offline
post #18 of 39 (permalink) Old 03-26-2016, 05:35 PM Thread Starter
Jordansaia's Avatar
ah found relay here. Diesel Rx Glow Plug Controllers DRX01004 - Free Shipping on Orders Over $99 at Summit Racing
this is a pretty cheap fix, if thats all im dealing with...
@arcticdriver whats best way to test heater? This is what I dug up
it seems pretty ridiculous
post #19 of 39 (permalink) Old 03-26-2016, 06:08 PM Thread Starter
Jordansaia's Avatar
and does anyone have an idea of what this device is that was mounted to the top of my alternator?
post #20 of 39 (permalink) Old 03-26-2016, 06:37 PM
Tough to see from photo but the cord almost looks like a 120v AC cord. Any idea where the other end runs to?
SOLD:
post #21 of 39 (permalink) Old 03-26-2016, 06:42 PM
@arcticdriver whats best way to test heater? This is what I dug up https://www.youtube.com/watch?v=fw03T7lHQMY it seems pretty ridiculous
Oneof the 6.9 guys can best tell you which GPR to buy since they are not all created equal.
Cheers
SOLD:
post #22 of 39 (permalink) Old 03-26-2016, 08:25 PM
79jasper's Avatar
Upgrade to the solid state system like the 7.3 has.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #23 of 39 (permalink) Old 03-26-2016, 08:32 PM
Jordan,
Do you access to a multi-meter?
If so then set to measure Ohms and touch one lead to each of the flat prongs on the block heater plug (ignore the ground prong).
You should get around 15-Ohms resistance. If you don't then either the cord is bad (common) or the heater element is bad (much less common).
If you do not have a way to measure ohms then you should be able to feel heat at the location of the block heater and the freeze plug hole its mounted in after its plugged in for an hour or so. I think on the 6.9 its obstructed by the starter though??
SOLD:
post #24 of 39 (permalink) Old 03-28-2016, 11:22 AM Thread Starter
Jordansaia's Avatar
Got some readings off truck.
Block heater and plugs are giving no readings.
12.3 v coming from batteries and gp harness
Glow Plug controller is giving 4.5 v cold and 10.7 volts running.
Is this normal?
Going to replace regardless, found a $20 duralast at local auto store. And I already mistakenly ordered this one with new diesel rx plugs:
http://m.summitracing.com/parts/DRX-DRX01004
Will that one work for an 84 6.9...looks exactly the same as what i have, but im sure insides could be different.
Thanks for all thw advice so far! Hope old plugs come out easy..
post #25 of 39 (permalink) Old 03-28-2016, 12:44 PM
^^^^^ That's the relay, not the controller, and yes, it will work. Cheaper alternative, proven reliable, is the Western Plow 56131K.
Re. the block heater - is the rebuilt engine a transplant? Or is it the original engine from the truck, rebuilt and re-installed? It would be good to get the engine serial number. The early 6.9 engines, up to the middle of the '85 model year, had a problem with the engine block, where there was a risk of the block cracking by using the block heater. Later blocks got a thicker casting in the area around where the block heater mounts.
madpogue is offline
post #26 of 39 (permalink) Old 03-28-2016, 02:13 PM Thread Starter
Jordansaia's Avatar
@Madpogue thanks for the reply. Took some shots of engine and serial. Previous owner told me it was original engine rebuilt
Also one other thing i noticed is that when i try the glow plug button on dash i get no sound like they are turning on anymore. This is new as of today. Guessing its bc of bad relay??
post #27 of 39 (permalink) Old 03-28-2016, 02:14 PM
Glow plug button? Something the PO installed? First thing I'd do is find out how it's wired, and whether that means the OEM glow plug control is disabled.
madpogue is offline
post #28 of 39 (permalink) Old 03-28-2016, 02:16 PM Thread Starter
Jordansaia's Avatar
Pictures here
post #29 of 39 (permalink) Old 03-28-2016, 02:30 PM
Look on the top of the block, driver's side, just behind the IP cover. You should see either a number stamped into the casting, or a plate with a number on it. That's the engine number.
madpogue is offline
post #30 of 39 (permalink) Old 03-28-2016, 02:59 PM Thread Starter
Jordansaia's Avatar
Yep its a temporary push button on the dash. Was working but now seems busted
Just had new alternator i put in tested and the voltage regulator failed, which i,just replaced as well.
Think i got the serial, image attached
