What's this fuel line gizmo? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 11-23-2010, 10:19 PM Thread Starter
I have an 84 e350.
Between the fuel pump and the filter there is a section of the line that's about an inch across and it has a wire coming from it.
It's not shown in my repair manual. My guess is it's a line heater.
I'm asking because I'm about to remove the mechanical fuel pump and switch to two electric pumps down on the frame and I'd like to know if I need that thing.
longwolf is offline
post #2 of 8 (permalink) Old 11-23-2010, 10:27 PM
You win....... You guessed right......
hawgman is offline
post #3 of 8 (permalink) Old 11-24-2010, 01:04 AM
And no, you don't need it.
Why 2 pumps on the frame? WVO?
Evel486 is offline
post #4 of 8 (permalink) Old 11-24-2010, 09:43 AM Thread Starter
Hawgman said it pretty well:
Each pump came with a check valve so I won't have to worry about a fuel selection valve on the sending side of the system.
longwolf is offline
post #5 of 8 (permalink) Old 11-24-2010, 10:15 AM
Joe Mc's Avatar
My Photos: (39)
Do you need a fuel heater?
You don't say where you live or drive.
If you ever drive in the cold and you don't mind sitting on the side of the road waiting for the filter to un-gel, then no you don't need the fuel heater.
Hawgman, I had a kenworth gel up just north of Houston one-time, you might want to reconsider not needing a fuel heater. Same trip in the same truck also gelled up in southern Mississippi, the Florida pan-handle, Tennessee and Oklahoma. It was a cold trip.
Red 86 F250 Supercab XLT: Longbed, 6.9l, 4 speed with DNE-2 Overdrive, 2WD, 10.25 Sterling 4:11, Reclining Highback Captains chairs with arm-rest, Holly Red pump, push-button glowplugs, Racor 645 water separator with fuel heater, K&N Air Filter, Headlight Relay Upgrade, Fog Lights, lots of extra lights, Isspro EV series: Pyro, Oil Pressure, and Voltage in a Autometer 3 pod A-pillar. Bulldog Security System with remote entry. Offset Mirror Upgrade, Remote lube TOB. Road Watch System coming soon. PB PS PW PDL CC AC IW
BOOB man - Brotherhood of Oil Burners
1995 Toyota Camry DX: 2.2L, Bolt-action 5-speed, AC, PS, PB, CC.
135,016 miles: Rear-ended and totaled by an uninsured kid having a temper-tantrum
1999 Rav4 AWD 5-speed, AC, PS, PB, CC, Sunroof.
Joe Mc is offline
post #6 of 8 (permalink) Old 11-24-2010, 06:04 PM
KJGehr's Avatar
I know if you bend it it will catch on fire, I have a new one but I havent replaced it yet, ive seen about 20 degree nights and I havent had a problem yet, but I plan on changing it here real quick
1978 F-350 XLT Super Cab 4X4, srw dana 60's, 17" ford superduty alloy wheels,Stake Body 6.9, finally ZF-5, 4.11 gears. 02 dodge Laramie seats,fact. 80's tach modded into ac vent in dash, push button G/P's Banks turbo set up ready to bolt on w/ 3' stainless full length exhaust, now to rebuild the heads
KJGehr is offline
post #7 of 8 (permalink) Old 11-24-2010, 09:34 PM Thread Starter
I live near Dallas, but I travel sometimes.
But you're saying the point is to heat the filter, so I guess the thing to do is move the heater down to the frame just before the new diesel filter and/or pump.
longwolf is offline
post #8 of 8 (permalink) Old 11-25-2010, 01:33 AM
Fuel heaters are federally mandated on automotive diesels. Their purpose is to heat gelled fuel enough to pass through the filter so you can start the engine. I've never actually seen one do this.
I live in northwestern Canada and tonite it's -25. Many, many diesel owners around here have their fuel heaters disconnected permanently. If you live in an area that doesn't winterize diesel you can protect yourself much better by adding an anti-gel to your fuel.
Evel486 is offline
