2019 F350 Trailer Battery charge stops - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By specialtystruct
post #1 of 4 (permalink) Old 05-19-2019, 02:06 AM Thread Starter
Greatings,
I have owned a few 2017 and earlier models, and am familiar with the sequence in getting the trailer charge wire to power up. I now have a 2019 F350 with factory installed tow package, gooseneck hitch and bed harness. It seems that the trailer battery charge line will ONLY stay on when the brakes are applied. As soon as you release the brake pedal, the charge stops. I have the trailer batteries set up to monitor the charge from the truck, shore power, and solar. I plug into a 2017, and it works great. The charge stays on after release of the brakes. The 2019 stops charging once released. Any ideas on the issue? The same trailer worked fine in my 2017, but not the new truck. Possible bad module? Truck has 130 miles.
specialtystruct is offline
post #2 of 4 (permalink) Old 09-01-2019, 09:01 PM
Not trying to hijack your thread.
But im trying to get my 2019 f350 to charge our rv also.
But this brings up a new test for me. To push the brakes while i check the battery charge. Ill test this tomorrow and report back.
Subbed!
brad2388 is offline
post #3 of 4 (permalink) Old 09-01-2019, 11:35 PM Thread Starter
Problem Solved
Thanks! After I posted this thread, I figured it out. For the 2019, and maybe similar for other years prior, you will need to add your trailer to the trailer section of your dash menu. In order to get a signal from the 7 pin connector, the engine needs to be running, and vehicle in park. Using the brake controller, apply the brakes and release. You might just need to apply the foot brake also, but not sure. The drivers door needs to be CLOSED. DO NOT leave the door open, and then try to check the signal at the connector. You will not get a positive reading with your test light with the doors open on the truck. It must be a safety feature with Ford to end battery charging when the drivers door is open.
Also, if you have key-less ignition (push button start), leave the key fab IN THE TRUCK. If the horn honks twice when you close the door, its still in your pocket.
If your truck is equipped with the factory installed trailer tow package, then you will not need to add the fuse in the engine compartment. Your truck will have the module installed that eliminates the added fuse.
I use a flush mounted led volt meter on my 5th wheel that I can view from my drivers mirror to monitor voltage to the trailer. (similar to the light on reefer trailers that truckers need). Its attached to a diode that keeps the trailer battery from back-feeding the led when the truck isn't charging the trailer.
ford_doctor likes this.
post #4 of 4 (permalink) Old 09-03-2019, 08:39 PM
Funny you found this too.
I too found out the drivers door must be closed to get it to charge.
I had my fifth wheel programmed in and i guess its been chargeing all along.
But yesterday i was trying to figure it out.
When you open the door with it chargeing you open the door and the relay clicks. Close the door and it clicks to start back charging.
Wierd i know.
brad2388 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
Similar Threads
2002 Excursion 7.3 trailer battery charge RAMROD5000 Towing and Hauling 3 11-26-2009 03:00 PM
Looking for Ford part#'s CSXPAID Power Strokes 1994-1997 General 7 03-27-2008 10:40 PM
Trailer Battery Charger mvanhaerents Towing and Hauling 10 06-17-2006 07:48 PM
Trailer Battery Charge 30 Amp Circuit SDSOMDAY Power Strokes 1994-1997 General 22 07-15-2005 06:53 PM
Battery Charge Pin Not Hot at Trailer Plug Gary T Towing and Hauling 15 05-16-2005 01:13 AM
