Adding LED pods to trailer - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 03-07-2019, 05:35 PM Thread Starter
I have a car-hauler trailer and I would like to add an LED pod to each rear corner for backing up at night. My trailer is setup with a 4-flat at the rear and it was my initial thought to wire the pods to that and plug in when needed. But then I worry about corrosion when not plugged in and protected. So perhaps I wire in a waterproof switch as well and leave it plugged in?
Or should I forget the 4-flat and just wire it to the running lights and hide a waterproof switch somewhere?
Anyone have any luck with certain waterproof switches?
Something like this?
2017 F-350 CCSB 6.7L
[old]2002 7.3L PSD, 6spd, 4x4 Off-Road, Super Cab, Short Bed, ARE Topper, SCMT Autometer gauges, Tymar, 4" SS aero-turbine exhaust, & WW.
'73 Bronco 351 SEFI, 35's & Locked!
Jesus_man is offline
post #2 of 13 (permalink) Old 03-10-2019, 11:23 AM
Steve83's Avatar
Why wouldn't you connect them to the trailer reverse lights circuit, and let the truck switch them on & off as needed? You said it has a 4-flat at the rear, but surely it has a 7-round at the front, right?
I like these because they're rugged, bright, inexpensive, & compact:
https://www.ebay.com/itm/392253182123
Steve83 is offline
post #3 of 13 (permalink) Old 03-10-2019, 04:31 PM
klhansen's Avatar
My Photos: (180)
You can't get power thru a 4-pin other than the running light or brake/turn-signal. There will be a blunt cut wire for reverse lights just forward of the rear bumper. You could wire a waterproof connector to that or like Steve suggested convert to a 7-pin. I would just go the 7-pin route. Some Ford trucks have a trailer connector with both 40pin and 7-pin receptacles. It should plug in where your 4-pin does. You can find those at a wrecking yard for a few bucks, or even visit your dealer and buy a new one.
), AIS,
regulated return,
klhansen is offline
post #4 of 13 (permalink) Old 03-11-2019, 08:44 AM Thread Starter
On another forum, I just found out that there is a reverse light circuit in a 7-round! So that is indeed the way to go! That will be a fun little project sometime when the weather warms a bit.
post #5 of 13 (permalink) Old 03-14-2019, 10:24 PM
Steve83's Avatar
You could have found that by clicking the diagram I posted above.
Steve83 is offline
post #6 of 13 (permalink) Old 03-15-2019, 09:19 AM Thread Starter
Agreed Steve, I just happened to get that same information on the other site a day before you posted here.
post #7 of 13 (permalink) Old 03-19-2019, 09:45 AM
I added a SPDT switch into that circuit on some of my trailers. The lamps at back of trailer are connected to the reverse light feed from truck or flip the switch and they are connected to the battery charge/power supply feed so I can use them as load lights for getting ramps out or down on the various trailers.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is online now
post #8 of 13 (permalink) Old 03-19-2019, 10:05 AM
Apologies if I seem to be hijacking this thread....
How are these for fog lamps up front?
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 257,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter, bellowed up pipes, rebuilt oil cooler, billet dip stick adapter, HD glow plug relay
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #9 of 13 (permalink) Old 03-19-2019, 10:35 PM
Steve83's Avatar
Pretty good.
(phone app link)
(phone app link)
(phone app link)
I'm also putting a set on my golf cart that I use around the house. And I put some on a friend's duck boat, and the back of the duallie in my avatar.
(phone app link)
Steve83 is offline
post #10 of 13 (permalink) Old 03-20-2019, 10:25 AM Thread Starter
They say they are a spot light, but they seem to spread out the light pretty well.
post #11 of 13 (permalink) Old 03-25-2019, 09:44 AM Thread Starter
Success!! So being colorblind and doing wiring can be daunting, but with the help of my son, I was able to get the trailer project completed this weekend!
1st order of business was to replace the uber-cheap connector that was just 5 wires wrapped in electrical tape with a cheap plug at the end. After labeling everything, I bought a new pigtail and changed out this:
to this:
My son helped run a new wire for the reverse lights thru the existing conduit. Then we soldered and heat-shrunk all the connections and we then wrapped up the new junctions in electrical tape and then fastened them to the trailer. After drilling some mounting holes and zip tying wire up, we ended up here:
[IMG]https://lh3.googleusercontent.com/4w_UOOgOGqYvJAwb4uFaGQG-oduE1cH6B13WBy9jky3vL2KkW0F8L6RxDYailwgw_95f1dXHcp p-HXb4bq7aVKNa3lUXyrH6r8GujapR7tFX2D02moHx8pBZAebivc d-toXNHslcV_tJmWiQSMBCVMIU6zHV88TwoNNwVbKlqQ1wjlMIf4 7syhjUUMLttt6Pf68qpGd95Z5nNwPcudImwyknWjYTmS03Bk9v UCVCV_lpgkogNOSVLomz5EE60G7f27sRl2IWDiBnp7d4y3hHSl YkXqVFTt17jHuxVGqmzm4uyBdwYwLrOVGlXCnuQLWp-wWEakaImJZhqiP8wW9z2lKBZ1hykdGi7zCZXQJf9iDAIQEZrxX ZTEBiF4SkPvaqrgFRxQoLDcly0mdJobNNaR0AQuZSnRvm-MSUKZxEPjJ04ijahOwkQX3bBd2Y3xwee-rjLzfmFfIX7bW7pN10ugqy1Xb-9mx1YqqGy2Rx_k4pBfzEEIeFmh7_TkiesNredFAQoleQ2KS5Yr fvavA4y52aAmswrsj0YKVZkiwXdq65Z***d7b7tYmTPrCXhvzl 9Xu9hZOIYae87qSBjCHN0-xh1C3z_vhPNoOPkkONBPVeYX9rBH1pV1xIkqk3gMOr4qNwtLGy SdM3P_wSq3XAR0KvH281C-FeTvXWAFm4NjcZliy5nmWlyhcsXo2t_0_VhGPY0rW8kQA8WPot K-fSrQyeFQ=w1165-h655-no[/IMG]
Hoping they throw enough light to make a difference, but if they don't it will be easy to swap to something that does. And also hoping this location is protected enough not to get torn off.
I was fairly shocked when i plugged it into the truck and everything worked the first time! Thanks for the help!
post #12 of 13 (permalink) Old 03-26-2019, 11:30 PM
Steve83's Avatar
For your next trailer:
4-foot with terminal box
8-foot with terminal box
BTW
You can tap that same circuit on the truck to add reverse lights to it, as shown on my duallie in a previous post.
Steve83 is offline
post #13 of 13 (permalink) Old 03-27-2019, 08:46 AM Thread Starter
Ahh snap! That would have been a good way to do it! But I am confident what I installed will last a long time as well!
I think I am ok with lighting on the truck with the light and cam in the tailgate, but that is a good idea.
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
Similar Threads
Ford F250 / F350 Reverse/Backup LED Bulbs! Plug & Play! Ships Same-Day Diode Dynamics Diode Dynamics 40 07-06-2018 09:12 AM
Auxiliary backup lights - trailer tow wiring how-to westvandude 1999-2007 Upgrades and Aftermarket - General 41 02-23-2010 10:49 PM
Led lights - want to switch out Horse trailer lights - best ? 02GVW Towing and Hauling 16 04-26-2005 09:24 AM
Adding Trailer Brake Controller to and Excursion Justin B Power Stroke Excursions 6 03-14-2005 12:19 PM
05 F350 Adding Trailer Brake? 05f350 Upgrades and Aftermarket - 6.0L Engine 0 08-18-2004 11:54 PM
