Advice please on setting up my tongue weight - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-17-2019, 02:57 PM Thread Starter
Big Horn's Avatar
When I initially set up my 18’ Fish & Ski behind my ‘02 F350 i bought a drop hitch to get the trailer back to level. I have been surprised on the amount of hitch bounce I get on rough uneven roads. I would like to check my overall weight and tongue weight.
How do the CAT scales work at the truck stops?
There is one located close to home in Litchfield IL close to where I fish sometimes.
What’s the best way to measure my tongue weight.
The boat trailer is rated 3500 lbs. max (single axle trailer)
With the 2 stroke 150 Merc, 24 gallons of fuel, and 3 12V batteries at the transom it puts a lot of weight behind the axle. Plus loaded with gear and it’s a heavy wood core fiberglass construction. Interstate, highways, and city roads, I never notice the boat behind me but with the airlift 5000 rear bags (5#) and new Rancho 9000 shocks I was kind of surprised to feel the boat bouncing the rear of the truck on bad roads.
Sorry for the novice questions on the scales—never towed anything big yet.... thanks!
(2002 F350 CC DRW 4WD 8’ Box)
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #2 of 3 (permalink) Old 05-18-2019, 08:58 AM
69mach1377's Avatar
There are good links to be found but the gist of it is you weight it twice with the rear tires on the same spot each time. First with the trailer and then w/o. The difference between the rear tire weights is the tongue weight.
You might want to drop the tongue lower and/or move weight forward is my guess.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #3 of 3 (permalink) Old 05-18-2019, 11:22 AM Thread Starter
Big Horn's Avatar
Thanks 69mach! I looked this morning and found a trailer tongue scale for sale on etrailer.com, I want to find out the weight first—then I have room to move the winch post forward a few inches which will move the whole boat forward...... if still not enough then I guess I’ll loosen the axle and move rearward. There’s really no way to shift any weight load inside the boat (still amazing that this heavy a boat will plane out and WOT to 60 mph, but the Merc is a XR4–supposedly equivalent of 165hp.
Eventually I’ll stop at the CAT scales or one of our local feed/grain services to see what my truck weighs.
Big Horn is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
Similar Threads
towing a 34ft tag etnovass Towing and Hauling 30 08-14-2014 11:23 AM
Towing Specs / Safety bbess00 Towing and Hauling 12 06-14-2011 06:49 AM
what is the max tongue weight 97 f350 crew cab leerickso Power Strokes 1994-1997 General 16 02-28-2009 10:21 AM
Max 5th wheel hitch weight? 4XFore Towing and Hauling 9 02-13-2007 03:28 PM
rear spring rates and tongue weight tacobuilder24 Power Stroke Excursions 7 02-12-2004 09:14 AM
