axle gearing and towing up hills - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 21 (permalink) Old 01-03-2019, 08:58 PM
I have a 93 dually with factory turbo , 4.10 and ZF5 trany. 215 tires , factory size. When first got the truck , used, it had a wide ratio transmission it. I pull close to 18000 to 20000 # behind it. Had to be really careful starting or backing up on much of a grade. Had transmission problem so rebuilt it to a close ratio. Lost about 10 mph on top end , but now it will pull. We have some pretty good hills and mountains here in Montana. Yes it pulls down on the hills , but still gets me there. Get around 15 empty and 8- 10 loaded , still run down the highway 65 -70 pretty easy. this is what I pull with mine.
LMJD likes this.
Randy 4614 is offline
post #17 of 21 (permalink) Old 01-05-2019, 10:05 AM
wpetko's Avatar
My Photos: (17)
Regearing a 4x4 truck is a big red flag for me because you would have to regear the front axle as well. I would first research auxiliary transmissions like Gear Vendors before I got into the differentials. Also, unless you are towing WAY too heavy & your truck is overloaded a 4.10 gear should be completely adaquate for any hills that you find in Florida. If the truck is having a hard time towing with your present ratios then maybe you should consider adding a turbocharger or other engine upgrades.
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
post #18 of 21 (permalink) Old 01-05-2019, 12:42 PM
SGT JUNK
So when you are towing at say 60 mph and you come up to a hill and start to slow down does you truck tranny shift out of overdrive? Simply dropping a gear lower in tranny will give you higher rpm and more power. What are your EGT temps and what is the location of the probe.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #19 of 21 (permalink) Old 01-13-2019, 03:07 PM
"Towing waaay to much weight" yes likely.
Shop goofed and put 4.88 in it, thank god they did. Gearing is spot on for what I wanted rpm at 55 in fourth and 65 in 5th with 315s on it. In break in now so can't pull my trailer to test. Kinda wish I did have them put positraction in it. They called halfway through the job and I said no. Regeetting that choice already... Had to put it in 4wd to get up my buddies driveway the other day. His driveway is dirt, it was raining, and it is a really steep climb.
montibank is offline
post #20 of 21 (permalink) Old 01-13-2019, 03:10 PM
Oh ... it already has a factory turbo. Not that it wouldnt do the job... it did just fine if I was willing to go 35 mph. 120 miles at 35 vs 120 miles at 55 mph is a huge difference in time.
post #21 of 21 (permalink) Old 01-13-2019, 03:11 PM
zf5 ... manual not automatic
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
