Gooseneck hutch pulled up by hydraulic jack - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 01-27-2019, 04:15 PM Thread Starter
Hi, new to owning a gooseneck. The other day, while unhitching with hydraulic jack, I didn’t open the hitch before trying to raise jack/trailer. When doing so, I heard a bit of a pop noise from truck bed, and immediately stopped.
Now the ball hitch seems a bit looser than it’s very tight self before. Any advice? Going to get it looked at at the ford dealer next week but curious on any opinions. Could a bolt underneath have come loose, or did i pop something when the jack basically pulled up on the hitch ball? Thanks!
Amy Peloquin is offline
post #2 of 7 (permalink) Old 01-27-2019, 06:43 PM
By all means have a hitch shop or the dealership look at it. Is it a flip over ball? could of damaged the latching pin for that , really kind of hard to say. Hopefully it is not to serious or costly to repair .
Randy 4614 is offline
post #3 of 7 (permalink) Old 01-27-2019, 08:29 PM
bobofthenorth's Avatar
You need to figure out what happened and IMHO you should be happy you did whatever you did. If there really is some damage done then your gooseneck ball or its installation was crap and you need to get it fixed. You should be able to literally lift the truck off the ground by that ball if its properly installed.
2006 F250 6.0 4x4
bobofthenorth is offline
post #4 of 7 (permalink) Old 01-28-2019, 12:08 PM
My Photos: (27)
There's 1/2 dozen hitch brands and as many mounting methods so it's impossible to advise over the internet. As Randy posted, take it by a trailer shop or dealer so they can check it out.
Things could be worse. At first I thought you were going to say you unhooked the latch, raised the trailer off the ball, then slammed the tailgate shut and then took off. I know 2 guys who did that years ago.
LMJD is offline
post #5 of 7 (permalink) Old 01-29-2019, 01:45 PM
Thank you! It is a flip over ball. Good idea. Getting it checked tomorrow.
Apeloquin is offline
post #6 of 7 (permalink) Old 01-29-2019, 01:46 PM
Thx! I am getting it checked tomorrow.
post #7 of 7 (permalink) Old 02-10-2019, 02:56 PM
STMPDUST's Avatar
hitch ball was more then likely moved up by a 64th of an inch very suddenly as it was in a bind, and made the noise, again you should be able to lift the truck off the ground when the trailer is attached to the ball with a jack or landing gear
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
Similar Threads
Hydraulic Cab Over Camper Jack Question The Reverend Floater Other Technical Questions 8 04-30-2012 11:52 PM
Floor Jack Center Jacking Point and Jack Stand Locations nitro3421 '99 & up 7.3L Power Stroke Engine and Drivetrain 11 09-16-2011 10:13 AM
Ramps and Jack Stands? 5thwheel-in 6.4L Power Stroke Engine and Drivetrain 9 08-22-2010 11:46 AM
Which jack do you use? HeavyfootHick 1999-2007 General Questions 23 10-30-2007 11:08 AM
5th wheel coupler on gooseneck trailer rcd Towing and Hauling 6 05-30-2005 01:24 AM
