Has anyone seen a hitch like this before? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 10-27-2018, 04:41 PM Thread Starter
08 f450, it measures 3” id and is fully secured under the bed only. Dealers, trailer shops and rv places around me have no idea. I’d like to find the correct ball and use it if possible.
Loadtoad is offline
post #2 of 12 (permalink) Old 10-27-2018, 06:39 PM
79jasper's Avatar
Have you looked on the underside for a tag anywhere?
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #3 of 12 (permalink) Old 10-27-2018, 06:44 PM Thread Starter
I have. Can’t find anything but a small scrap of black paint on it
Loadtoad is offline
post #4 of 12 (permalink) Old 10-27-2018, 07:35 PM
bugman's Avatar
My Photos: (12)
I would check at a heavy truck trailer shop. With the truck being a F450 I doubt that any regular trailer shop or RV shop will know.
bugman is online now
post #5 of 12 (permalink) Old 10-27-2018, 10:40 PM
While not completely sure I believe this is what is called an inverted ball coupler, have only seen one years ago. And after trying to look it up found one made by B&W.
Randy 4614 is offline
post #6 of 12 (permalink) Old 10-28-2018, 12:04 PM
Steve83's Avatar
The B&W Turnover Ball gooseneck receiver uses a pull-rod to retain the ball in the square receiver. That one uses a a bayonet-style round socket, like older automotive light bulbs (push & twist).
You might be able to find a tag or embossments if you clean that thing.
Steve83 is offline
post #7 of 12 (permalink) Old 10-28-2018, 12:40 PM
Gooseneck ball? All farm and ranch stores have them.
2011 KR F-450 DRW
2018 ForestRiver Riverstone 39FK
2015 FLRT120ST Harley Trike
tzman is offline
post #8 of 12 (permalink) Old 10-29-2018, 06:52 AM
My Photos: (27)
You don't just buy a gooseneck ball, the shank has to fit whatever style the brand the hitch assembly is. My Atwood Hide-A-Ball has a round shank with a pin through it to rotate upright or flat, B&W are square shanked and pull in and out.
Whatever it is, it's definitely an oddball.
LMJD is offline
post #9 of 12 (permalink) Old 10-29-2018, 12:40 PM
https://www.delcity.net/curt?id=Towi...20group%20%231
This one looks like the sort of thing that you are looking for. It's probably not the exact one that you need, but it may be similar to what you need.
DonWarkentin is offline
post #10 of 12 (permalink) Old 10-29-2018, 11:53 PM Thread Starter
After about 3 days of google I just figured out it’s made by a small company in Colorado called Cody Hitches. Seems like a nice product just impossible to find and unheard of.
Loadtoad is offline
post #11 of 12 (permalink) Old 10-30-2018, 08:41 AM
My Photos: (27)
Originally Posted by Loadtoad View Post
After about 3 days of google I just figured out itís made by a small company in Colorado called Cody Hitches. Seems like a nice product just impossible to find and unheard of.
Seems like I vaguely remember those Cody hitches, maybe adds in Trailer Life mag. They definitely were not a best seller. Back in the day most all of us had a Buyers or Atwood hide-a-ball:
https://www.homedepot.com/p/Buyers-P...E&gclsrc=aw.ds
Later B&W has captured the market, top of the line IMO.
LMJD is offline
post #12 of 12 (permalink) Old 06-06-2019, 10:20 AM
Its a gooseneck hitch made by Cody. Also known as Quick-Hitch Inc.
DBHitchGuy is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
