Realistic Towing Capacity - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Steve83
post #1 of 5 (permalink) Old 05-27-2019, 05:47 PM Thread Starter
Hey everyone and thank you for having me.
I currently own a 99 F250 extended cab single axle with the 7.3. By far the best truck i have every owned.
I have a question regarding realistic town. I'm a small farmer and the truck carries a single round bale of hay off my spear anywhere i need it to go. I am currently shopping for a round bale hay hauler gooseneck, and am wondering if anyone has any experience with them. I don't want to overload the truck, and don't plan on driving cross country,. max 3-4 hours one way. The truck is complete stock with standard trans. I want to buy the round bale hauler that best fits the truck.
Appreciate any guidance with this.
parksfamilyranch is offline
post #2 of 5 (permalink) Old 05-28-2019, 02:47 AM
Soooo, if it can tow the load for one hour it will do fine for 48 hours(to some people 4 hours is cross country)!!! If you want to be legal you are looking at around a 12,000 lb load including trailer. If you are are not pushing hills and do not need to pass any one it will pull more but it will be over the legal GVWR. How about some more info. Total miles on truck and tranny/auto or manual/ what part of the country/ any mods to the truck/early or late model 99?
DENNY
DENNY is offline
post #3 of 5 (permalink) Old 05-28-2019, 08:31 AM
Steve83's Avatar
There is no "towing capacity" or limit - the truck can pull a battleship, for a short distance & at a low speed. The only hard limits are the legal ones when on public roads. If that's what you're asking, it's explained in the owner's manual:
http://www.fleet.ford.com/partsandse...owner-manuals/
If you're asking what you'll be comfortable towing regardless of legal technicalities - only you can say. The more you drive the truck, the more you'll know how to tow, and the more-comfortable you'll be. So to start, stay low, and work your way up slowly. Don't jump from a single bale to 20.
If you're asking what will hurt the truck - that depends on how well it's maintained, and the quality of the towing equipment you use. You can certainly find a brand new cheapo trailer; and you can find a well-built one, which will probably cost a little more (because it'll be a better design, with thicker steel, and stronger suspension on better tires). Same for the hitch. I don't have one, but if I get another big pickup, I'll put a B&W Turnover Ball on it.
So to give you more-specific answers, you have to supply a LOT more-specific information. It's better for you if we can see it all in your signature so we can review it every time we want to reply, without having to ask or go digging back through your old posts or threads. Look at DENNY's signature, and read this caption:
(phone app link)
85351ho likes this.
Steve83 is offline
post #4 of 5 (permalink) Old 05-28-2019, 06:33 PM Thread Starter
I will get more Information for you all in the morning when I get back to to house. Never thought about the signature idea but I'll get it done make it easier. Thanks for all the input.
post #5 of 5 (permalink) Old 05-29-2019, 04:05 PM
Steve83 gave you the link to the owner's manual, repeated here.
Go to the diesel supplement page 16, where it gives your GCWR of 20,000 lbs. for gooseneck. Weigh your truck, and subtract that weight from the 20,000 lbs. That is the maximum weight of your trailer and cargo. Subtract the weight of the trailer to get the cargo capacity. Weigh your round bale to see what it weighs. Divide the cargo capacity by the weight of one bale to get the number of bales that you can carry. Look for a trailer that can carry that number of bales. Also check the driver's side door pillar to see what is the GVWR of your truck. A gooseneck trailer carries about 25% of its weight on the hitch. For example, a 5 bale trailer with two 6,000 lb axles would carry 12,000 lb on the trailer axles and 4,000 lb on the hitch. A 4 bale trailer with two 4,500 lb axles would carry 9,000 lbs on the trailer axles and 3,000 lb on the hitch.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Towing and Hauling
