17' 250 Water In Fuel Warning Reduced Power - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By Stroking it
  • 1 Post By gearhead1011
post #1 of 8 (permalink) Old 02-18-2019, 07:36 PM Thread Starter
Hi guys,
So got my 17 new off the lot back in June of 18. I just hit 20k miles. Last Friday the WIF warning came on while i was on my way home from work. I was planning to do an oil change on saturday so figured I would drain it while doing that. Saturday i started the truck and the WIF warning was gone. Took the trash to the dump, hit the car wash and Advance auto for a few things and it was off the whole time. So i do the oil change, fill the DEF and other fuilds and I drain the fuel conditioner. I let the fuel sit for a few hours and it didnt appear to have any water in it. primed the system and truck was running perfect with no WIF warning.
I didnt drive the truck Sunday but today the WIF warning and reduced power warnings are on. So i hit the dealer and grab a fuel filter kit figuring i might as well change it out if I am draining down the conditioner again. So I get home and drain it out (again no water appears to be in the fuel) again and change the filters. Prime the system and no change. So I decided to go fill it up with fuel. Took 20 gallons. Truck is running perfect with no issues. I get home I drain it down again, pop out the WIF sensor, clean it with electrical contact cleaner, clean the connections, put it all back together and no change. Still have the WIF warning and the reduced power notice.
Is there some reset for this thing?
Does anybody know the theory of operation for for the sensor system?
Its got 3 wires going in. Also appears to have a switch on the sensor?
Anyone got any ideas before I head to the dealer?
Luke
lukedwag is offline
post #2 of 8 (permalink) Old 02-19-2019, 11:43 AM
ford_doctor's Avatar
I am having trouble finding information on this for 2017 model year. I can tell you that in past model years that if the WIF lam is illuminated for a certain amount of time the engine will be put in de-rate mode. With that said, you may have triggered that or there is another fault with the WIF circuits or the sensor. There are only three codes related to the WIF sensor and not knowing which may be set. Regardless, code(s) may need to be reset along with the WIF Counter parameter. I would see your dealer. If I find anything more I will post it.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 8 (permalink) Old 02-19-2019, 09:31 PM Thread Starter
Thanks for the info. I did scan for generic codes but without a better tool I couldn't dig very deep. So last night I disconnected the harness thinking maybe it was wet and giving a false signal. I shook it out and cleaned it and the sensor again with QD then blew out with air. Started the truck and all was well. I start it this morning and it's back to the same. I had several stops to make today and after my first off and back on cycle it's off and hasn't been back since.
lukedwag is offline
post #4 of 8 (permalink) Old 02-20-2019, 04:39 AM
Shouldn't have to dig too deep as the code would be set in the PCM. If you have verified that there is no water in the seperator it's likely the sensor is crapping out on you. Not a high failure rate item but I have replaced a couple for this concern over the years. I have replaced more for being broken.
post #5 of 8 (permalink) Old 02-20-2019, 01:59 PM
Your truck is still under warranty. Why are you doing all this stuff to your truck when the dealer will investigate the CEL for you free. I only change my fuel filters every 30,000 miles so yours should be ok. I do like the idea of draining some fuel from the filter to see if you do indeed have a water problem. When you found none it's dealer time.
ford_doctor likes this.
Stroking it is offline
post #6 of 8 (permalink) Old 02-22-2019, 07:33 AM
gearhead1011's Avatar
My Photos: (10)
If you have a 6.7 truck that's not nearly frequently enough. Ford recommends a 22,000 mile interval and most guys go 15,000. That might seem a little excessive but it's cheap considering the cost of a fuel pump failure.
lincster likes this.
2012 F250 XLT
6.7 CCSB 4X4 Sterling Grey, B&W Turnover Goosenech Hitch, Air Lift LoadLifter 5000, 50 gallon Transfer Flow replacement tank, Weather Tech mats
gearhead1011 is offline
post #7 of 8 (permalink) Old 02-23-2019, 01:32 PM
Phillippeterson's Avatar
The manual for my 2017 SuperDuty says on page 579 to change the fuel filters at 30,000 miles.
Phillippeterson is offline
post #8 of 8 (permalink) Old 02-24-2019, 06:09 AM Thread Starter
That's weird cause mine says 22,500 on the same page.
I'm going to end up doing fuel filters every other oil change which I'm doing 7500 miles on those.
I don't buy into this "if the lights on it's already too late logic" we should all sue Ford if that's the case for stupidity in design. If your doing regular fuel filter changes and you do drain it down and do some investigation when the light does come on it I don't think you will have a problem.
I ended up pulling the plug end apart and finding one of the wire gaskets not installed correctly. Put a little silicone on them and all appears to be well.
As for the dealerships we have around here: I called the 3 local ones about the tsb for death wobble and they had to ask me where I found the the tsb. I was then told it would be 3 to 4 weeks before they could get me.
I personally have no interest in dealing with them. Unless I have a major warranty issue I will continue to do my own service and document.
lukedwag is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 and up 6.7L Engine and Drivetrain
Similar Threads
Need Help with no power to fuel pump and no start red1978 '99 & up 7.3L Power Stroke Engine and Drivetrain 4 09-23-2016 10:09 PM
Water in fuel removal additive ajohansson General Diesel 5 09-26-2013 01:51 PM
NEW HERE WITH QUESTION bigdw58 '11-16 General Questions 18 04-23-2013 12:19 AM
2 Stroke Oil redneck_rheino 6.0L Power Stroke Engine and Drivetrain 94 03-23-2011 08:37 PM
Fuel additives & highway use taxation? Lee Haenschen General Diesel 5 05-29-2008 02:53 PM
