2017 Super Duty Code: P1635 - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 02-27-2019, 05:54 PM Thread Starter
Scully777's Avatar
I have a 2017 that I put a 2.5" lift on with 35x12.50R20's on and this code is now pulling. I know its saying the axel and tire is out of calibration which I would think is an easy fix but the Ford dealers are telling me that they can fix this issue. This has to be complete BS because even the dealers are lifting this trucks and selling them. There is no way they are selling them with the check engine lights on so any thoughts on how to get this addressed? Just keep going to different dealers? Located in Scottsdale AZ.
2001 F-250 Lariat, Super Crew, Short box, 7.3L, 4X4, 4R100 Trans, 4.10 gears with limited slip, 3.5 Fabtech Suspension leveling kit, 35 12.50 20 Nitto's, 20 Fuel wheels, MBRP 4" turbo back exhaust, ceramic coated bellowed up-pipes, GPR LED, Dieselsite.com EBV+, Turbo Master mechanical wastegate controller, Ford Severe Duty AIS w/ foam fender sleeve, Diesel Site Boots, AIH delete with a Riff Raff Diesel plug, and a DP-Tuner F6, pre-pump fuel filter setup, coolant filter and bypass setup, trans filter, fuel pre pump filter, HPX line and some other small crap I cant recall.
Scully777 is offline
post #2 of 4 (permalink) Old 02-28-2019, 11:25 AM
ford_doctor's Avatar
Your dealer is correct. Once upon a time we could reconfigure the appropriate modules to reflect the tire size by calculating "revolutions per mile" and even then there were limits. Now, all we can do is choose from a list of available tire sizes presented which include only the available production tire and wheel sizes for that model. I will only add that I have not looked into this for quite a while so I am assuming this is still the case. If I get the opportunity to check in the short tem I will do so. I understand that there are aftermarket solutions for this concern...
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 4 (permalink) Old 03-01-2019, 01:44 PM
Check with Rodeo Ford in Goodyear. They had a lifted F350 with at least 35" tires. I wasn't interested in a lifted truck, but was curious how they could sell a truck configured like that given that everything is tied to computer programming. They said that they reprogram the computers and all works as it should.
RCinLaveen is offline
post #4 of 4 (permalink) Old 03-07-2019, 09:37 AM Thread Starter
Scully777's Avatar
took it to another dealer and found a service writer who got it. He took care of it in less than an hour.
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 and up 6.7L Engine and Drivetrain
Similar Threads
'08 Super Duty retro fit for a '2017 8ft bed swap?? Is it possible? yosemite917 2008- 2010 General Questions 3 11-10-2017 08:27 AM
'2016 or '2017 Super Duty F350 6.7L Which To Buy? bigredmontgomery 6.7L Power Stroke Engine and Drivetrain 11 03-08-2017 06:06 PM
2017 Super Duty Video Cavalier240 '11-16 General Questions 3 09-23-2015 08:54 PM
Share 2017 Super Duty updates Phillippeterson '11-16 Ordering Information 3 08-08-2015 07:58 AM
Super Duty PCM Code in an X BigBird Power Stroke Excursions 0 03-26-2001 06:30 PM
