Is 210 degrees an important transmission temp? - Page 2 - Diesel Forum - TheDieselStop.com
 6Likes
post #16 of 19 (permalink) Old 06-18-2018, 06:32 AM
ArcticDriver's Avatar
https://ford.oemdtc.com/TSB/16-0087.pdf
ISSUE
Some 2011-2016 F-Super Duty crew cab pickup vehicles equipped with an 8 foot box and a factory trailer hitch may exhibit a vertical vibration, often described as hopping, from 68-112 Km/h (42-70 MPH).
SOLD:
ArcticDriver is offline
post #17 of 19 (permalink) Old 06-18-2018, 08:29 AM
Unhappy
Originally Posted by lincster View Post
The Ford bounce is when the rear end bounces up and down at certain speeds.
Ford actually came out with a TSB where they mount a counter weight on a rear section of frame of the truck to try and offset the bounce.
And some here have tried it and reported that doesn’t work.
CajunMick is offline
post #18 of 19 (permalink) Old 06-18-2018, 08:31 AM
ISSUE
Mine. 2011, short bed or box and bounces.
post #19 of 19 (permalink) Old 06-21-2018, 09:06 AM
Back to the tranny temps. The 7.3 uses a completely different ATF than the 6.7. Yes, you will see high temps pulling a load up a long grade even with the ambient less than 32F.
Nickelplated5s is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 and up 6.7L Engine and Drivetrain
