Crank case pressure and oil smoke at operating temperature - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 08-26-2019, 04:07 PM Thread Starter
o5excursion's Avatar
2017 with 124,### miles. EGR, DEF, DPF ALL DELETED. Just replaced the turbo because of the bearings failed. Drove for one day (60 miles) and the white smoke out the tail pipe after at operating temperature was ridiculous. NO LOSS OF POWER, NO HESITATION, NO CODES, RUNS GREAT... Had the injectors scanned individually and they all checked out good. Came home from a test drive (getting it up to operating temperature) and removed the oil fill cap and it almost shot out of my hand. Doesn't seem to have back pressure when cold. Looking for idea's. I've talked to a few diesel mechanics and they all do not agree on the same fix. Cracked piston? Wouldn't it swell up and either crumble or not compress both ways (no loss of power or hesitation)... Bad injector or injector seals? Wouldn't this cause a CEL or at least run rough...... clogged or blocked CCV ? I do not know enough about this engine to know this . Any help or way to pinpoint the issue would be greatly appreciated.
2005 Excursion - 8" lift - 37" Toyo M/T on Diesel wheels - K&N - BullyDog GT tunner w/EGT probe -Sinister EGR delete - 58v ficm - black onyx HG - ARP studs
o5excursion is offline
post #2 of 3 (permalink) Old 08-27-2019, 11:39 AM
ford_doctor's Avatar
If you suspect a clogged CCV filter there WILL be excessive oil carryover in the turbo inlet. I have had a few that were high idle applications mostly. High miles are not out of the question as the filter which is serviceable does have a service interval.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 3 (permalink) Old 08-28-2019, 08:06 AM Thread Starter
Problem solved, ran it for 60 miles with the oil fill cap off and no smoke or oil. Ordered the CCV relocation kit and its done .
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 and up 6.7L Engine and Drivetrain
