New 19' 6.7 shimmy - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-26-2019, 02:52 PM Thread Starter
New 19' 6.7 shimmy
Have a new 1 ton, I can pull a boat with a tandem trailer a 8' utility trailer with no issues. I pull my 3 place snowmobile trailer with a utv on it and I get a shimmy. Tryed everything I know. It's a shimmy pause shimmy pause all the time. Any ideas. Thanks mark
Neusch is offline
post #2 of 5 (permalink) Old 08-26-2019, 10:07 PM
Maybe not enough tongue weight?
'19 F-350 CCLB Lariat SRW Fx4 PSD
Ordered 2-Oct-18 arrived at dealer 20-Nov-19
Sport45 is offline
post #3 of 5 (permalink) Old 09-03-2019, 04:21 AM
HeavyAssault's Avatar
My Photos: (6)
Well your shimmy could be different than my interpretation of a shimmy. Can you be a bit more descriptive of the issue??
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #4 of 5 (permalink) Old 09-04-2019, 09:38 AM
Does it do it with no trailer? Have you checked the trailer tires well? I know my trailer tires will not balance, and I get a vibration from them at certain speeds. On my list to do is break down the tires and put in balancing beads.
2017 F-350 CCSB 6.7L
[old]2002 7.3L PSD, 6spd, 4x4 Off-Road, Super Cab, Short Bed, ARE Topper, SCMT Autometer gauges, Tymar, 4" SS aero-turbine exhaust, & WW.
'73 Bronco 351 SEFI, 35's & Locked!
Jesus_man is offline
post #5 of 5 (permalink) Old 09-08-2019, 10:18 AM
It's the trailer causing it, not the truck. The 19 uses the same aluminum body as the F-150 and it is super sensitive to oddities such as an imperfectly balanced trailer, or an improperly torqued trailer wheel and they can be felt in the cab. I had pulled a flatbed with mine, and got to 60 and the truck shook like crazy. Turned out a wheel was not properly tightened on the trailer, smooth as silk afterwards. Had it been my 14, would not have felt it.
In your case, you are getting trailer sway, move everything forward to get more weight on the tongue, and/or drop the ball down a bit to lower the tongue and your problem should go away. A little trailer sway with a SD should not be felt, but with the new aluminum body, it just might be felt more than normal.
DD 2018 F150 Platinum 3.5 EB
Sold due to neglect
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 and up 6.7L Engine and Drivetrain
