International 4700, 7.3L - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 06-06-2006, 10:59 PM Thread Starter
have a international 4700 with a 7.3. having a problem keeping it running after i drive it about a quarter mile, looses power and then quits. it will restart with diffulity. will idle ok but when under power the engine knocks and quits. i thought i had water in fuel and drained half tank and put new diesel in and still same problem. next i want to change fuel filter but i never changed one. any help out there would be apprecited. or any other thoughts?
biobarry is offline
post #2 of 11 (permalink) Old 06-06-2006, 11:12 PM
cdnsarguy's Avatar
My Photos: (109)
re: International 4700, 7.3L
Welcome to TDS.....
I'm not up on 4700's but does it has a spin off filter.........
Does it have a manual lift pump....
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 11 (permalink) Old 06-06-2006, 11:19 PM
I believe the fuel filter setup on the Internationals is very similar to Ford. The spin on fuel filter (and water seperator drain) should be on top of the motor.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #4 of 11 (permalink) Old 06-07-2006, 12:07 AM Thread Starter
i have two spin on filters a chemical and a oil filter, it has a blue plastic water drain on top on the engine and that has a smaller filter on the back side of it. i think its a filter incased in the round plastic. does this come apart to drop a filter into?
biobarry is offline
post #5 of 11 (permalink) Old 06-07-2006, 12:22 AM Thread Starter
has no spin on filters except a chemical and a oil filter. i just bought this truck and i know nothing about the lift pump. i know the pump is working have a lot of fuel coming out of the fuel bleder when running
biobarry is offline
post #6 of 11 (permalink) Old 06-07-2006, 08:10 AM
What year International are we talking about?
I suggest going to the International dealer and asking for a fuel filter. Then once you have it in hand you can figure out where it goes.
post #7 of 11 (permalink) Old 06-07-2006, 09:45 PM Thread Starter
it is a 96 international low pro with a 7.3 turbo 444, went to napa today and bought a fuel filter and water seperator $60, and seen a picture where it goes. it has a blue plastic housing on top of engine and filter goes in it. tried to unscrew lid to get to filter and it is on very tight. tried everything from a screwdriver to a round piece of rebarb, got lid to loosen about one eighth of an inch before part of the plastic lid broke off the top. went back to napa and bought a new lid to screw onto housing. another $18, will try tomorrow to get lid off. has anyone else had problem getting lid off? do they make a special wrench for taking lid off? also on the back of housing there is a smaller round housing that looks like it has a small filter in it as well, but napa did not have a filter for this, maybe it isn't a filter housing after all. took water seperator back because my truck does not have one. i am wondering why!
biobarry is offline
post #8 of 11 (permalink) Old 06-07-2006, 10:02 PM
OK, a 1996 is a T444E (Ford 7.3 Powerstroke) which is a completely different engine that the International / Ford 7.3L IDI. You need to move a few forums up.
At least for Ford, the last year for the 7.3L IDI was 1994, I assume International switched over about the same time since they have probably used the same assembly plant to make both engines.
post #9 of 11 (permalink) Old 06-08-2006, 08:09 AM
My Photos: (23)
I was going to say, I don't think the IDI's came in anything other than an S series IH truck or bus.
- Mel
1983 F-250HD 4X4
55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW
1987 Bronco
1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
agnem is offline
post #10 of 11 (permalink) Old 09-08-2017, 04:27 PM
I have a 7.3 also just opened the fuel filter top today with a 4 inch round common strap oil filter wench.
post #11 of 11 (permalink) Old 04-26-2019, 11:54 PM
Thinking about buying an International 4700 with the t444e engine...... it has an Allison 545 auto trans and the current owner says it starts but wonít move because of the neutral safety switch he thinks....... anybody out there have any experience with that engine and trans combo and issues that they have?
Caziercustoms1 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
