Opinions - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 18 (permalink) Old 02-22-2019, 07:58 PM Thread Starter
Question Opinions
Hey hey hey, I am admittedly a novice rookie about diesel engines. I have a 2015 super duty 250 6.7 . And I am learning but because I am a curious soul I am wondering if the old pre-government involvement, Did the diesels run better or have advantages that the newer ones do not have ? Also is there any manufacters that make a hand crank starter system? I don't really know why I would ask, but. Anyway if any one has the time please reply
RGVAL is offline
post #2 of 18 (permalink) Old 02-22-2019, 11:15 PM
klhansen's Avatar
My Photos: (180)
Hand crank on a diesel???
May work if you have Hercules as a companion. Or maybe a spring wind affair that takes an hour to wind up.
As far as pre-emissions controlled diesels, you'll get opinions all over the range. A lot of the emissions controls actually allow more power, but add complications.
), AIS,
regulated return,
klhansen is offline
post #3 of 18 (permalink) Old 02-23-2019, 12:13 AM
My old pre-government involvement diesel has the advantage over your diesel in that mine doesn't require DEF. However, your diesel has almost twice the horsepower, torque, and towing capacity of mine.
And no, my diesel cannot be started with a hand crank.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #4 of 18 (permalink) Old 02-23-2019, 02:21 PM
bugman's Avatar
My Photos: (12)
I wouldn't say that it couldn't be started with a hand crank. With gear reduction and enough leverage just about anything is possible. But you would most likely have to have it attached to a trailer to haul around to start a diesel.
bugman is offline
post #5 of 18 (permalink) Old 02-23-2019, 08:22 PM
Wow, that creates quite a picture. Although, I'd have to see it to believe it. Would make an interesting project for those who are always looking for the next great upgrade.
post #6 of 18 (permalink) Old 02-24-2019, 09:54 AM
Some of the older stationary Diesels had a hydraulic starter motor. A pressure system with a hand pump supplied the pressure. Just pump it up for 10 min and hope it starts. Anyone that was around L.A. back in day can see the benefits of the emissions laws/equipment on new vehicles.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #7 of 18 (permalink) Old 02-24-2019, 12:01 PM
ArcticDriver's Avatar
DENNY
Not uncommon for even smaller marine diesels to have had a pnuematic system for starting. Even a sailboat with Yanmar 3-cylinder had one “back in the day” 😉
SOLD:
ArcticDriver is offline
post #8 of 18 (permalink) Old 02-24-2019, 12:39 PM
bugman's Avatar
My Photos: (12)
Back when I was working in the oil fields of norther Utah and southern Wyoming I remember the big rigs that had the pneumatic systems for starting. They all carried air hoses for when their air tanks would loose pressure. It wasn't uncommon to see two trucks sitting next to each other with a air hose running to the one that was not running so that they could try and start it at a -40 F.
bugman is offline
post #9 of 18 (permalink) Old 02-25-2019, 08:18 PM
https://www.bing.com/videos/search?q...il&FORM=VIREHT
Here you go. Apparently, it is possible to start a diesel with a hand crank. Here is the U-tube to show you how to do it.
post #10 of 18 (permalink) Old 02-25-2019, 11:13 PM
klhansen's Avatar
My Photos: (180)
LOL
That's really convenient. Don't try it with an auto tranny truck though.
), AIS,
regulated return,
klhansen is offline
post #11 of 18 (permalink) Old 02-27-2019, 07:08 PM
Originally Posted by klhansen View Post
LOL
Yet another reason why my next truck is gotta be a handshaker.
post #12 of 18 (permalink) Old 03-02-2019, 10:08 AM
My Photos: (27)
Yep, I ran across a few trucks years ago with air starters. Those babies were LOUD! Made an impact wrench sound like a whisper.
LMJD is offline
post #13 of 18 (permalink) Old 03-02-2019, 10:24 AM
Yeah, I used to live a block away from a trucking yard back in the day when they used to use the air starters.
That's quite a way to be woken up in the morning!!!
LMJD likes this.
post #14 of 18 (permalink) Old 03-06-2019, 09:48 AM
My Photos: (27)
I remember years ago when this subject came up regarding how loud they were, a couple goofy wannabe "truckers" that owned IDI Ford diesels asked how they could adapt an air starter to their pickups, yeah, right! Gott'a love the forums for free entertainment.
LMJD is offline
post #15 of 18 (permalink) Old 03-06-2019, 02:38 PM
https://www.ingersollrandproducts.co...-starters.html
See the link above for air starter information. Who knows? Maybe some clever goofy wannabe trucker can figure out a way to adapt one of these starters for use on their pickups.
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Similar Threads
I Need Tires and Opinions lone_star_dsl Wheels, Tires, Brakes, and Suspension 9 06-27-2011 02:32 PM
1985 6.9 f-250 opinions needed XanRa 6.9L IDI Diesels (Not Power Strokes) 16 07-08-2010 04:56 PM
375/55R16? Any Pics or opinions? Gotrox Upgrades and Aftermarket - 6.0L Engine 7 03-13-2009 04:44 PM
EDGE Juice Chip with Attitude.. opinions? tooofast '99 & up Upgrades and Aftermarket - 7.3L Engine 17 06-21-2005 10:50 AM
Opinions please willpower 1999-2007 Gas Engines 10 06-29-2003 10:51 PM
