Adding 12v DC Power Outlet - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-10-2017, 07:14 AM Thread Starter
I have my own TPMS to monitor the tires on my Airstream and for now, I'm going to use it before I spend the cash/time/effort to transition over to Fords TPMS system. I like to keep the TPMS display monitor by the driver door post. I also have a dash camera that records when driving. Last thing I want is wires draped over, across, around the dash, so I'm thinking that I can buy a three or four port 12vDC distribution port and mount it up under the dash by the steering column. Now here's the issue, finding a power source. At this point the only power source is from the up-fitter switches. I'd have to route the power distribution power wire out through the firewall and then connect to the up-fitter switch wiring bundle. Anyone been down the road? I'm open to suggestions. Wish that Ford had put a couple USB connection in the overhead console. Thanks
Tsunami01 is offline
post #2 of 7 (permalink) Old 10-11-2017, 02:42 PM
Kraig1957's Avatar
I put a carpeted dash mat cover over the wires draped across the dash. I have an HD camera on the windshield, and power a Radar/Laser Detector that also shows my speed using internal GPS. I used velcro hook on the bottom of the detector to attach it to the pile of the dash mat cover.
2016 F350 DRW FX4 Lariat King Ranch Crew Cab 6.7 V8
2011 F350 SRW 4X4 Lariat Crew Cab 6.7 V8 (Sold)
2006 F450 DRW 2X4 XLT Stake Bed Crew Cab 6.0 V8 (Sold)
2016 Mustang GT Premium 5.0 V8
2003 Crown Victoria LX 4.6 V8
1967 F100 Pickup 352ci V8, C6 automatic
1972 Pontiac Lemans 400ci V8, Turbo-Hydromatic 400
1964 Pontiac Catalina 389ci V8, Roto-Hydromatic 375 (Slim-Jim)
Kraig1957 is offline
post #3 of 7 (permalink) Old 10-14-2017, 08:13 AM
wingnut60's Avatar
What dash cam are you using? Work ok, happy with it? Does it continually record and roll over? Max memory?
Thanks,
Joe
2017 F450 KR
2010 F450 Lariat 4x4--died, but reborn, traded
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
post #4 of 7 (permalink) Old 10-14-2017, 03:32 PM
Kraig1957's Avatar
Thanks,
Joe
I use the Cobra drive HD with GPS. It came with an 8 GB microSD card that I changed to 32 GB (the maximum size it allows). It records in 3 minute files that get written over when full. The 32 GB card holds about 100 three minute files. I keep an extra 32 GB MicroSD card I can swap out if there is something I want to save. It works ok, the only thing I noticed is any files shorter than 3 minutes (partial files when ending a trip) don't have audio. I shut the unit down when I get to my destination.
post #5 of 7 (permalink) Old 10-14-2017, 08:44 PM
wingnut60's Avatar
Is it powered from the truck, or just a battery? I have a couple of GoPros and to me, they are difficult to use, can't power from truck, and overheat regularly. Need to get something dependable that runs all the time the truck is on and overwrites unless stopped to save something. More and more, I am encountering some near-hits that others cause and I want to have video as a backup.
Thanks,
Joe
2017 F450 KR
post #6 of 7 (permalink) Old 10-14-2017, 10:52 PM
Kraig1957's Avatar
Thanks,
Joe
It comes with a 12 volt plug that will fit in the cigar lighter / power port of the truck, or you can use a mini usb connector. I have used it on a drive from central California to Denton County Texas and back (3200 miles round trip) with no problems. I never go anywhere without the camera on, and it is powered by the vehicle. If you want to be sure the audio is also recorded, you need to keep the camera recording for at least 3 minutes beyond an incident. The camera is 1080p HD.
post #7 of 7 (permalink) Old 10-15-2017, 07:37 PM
wingnut60's Avatar
Thank you, sounds simple enough for even me to use.
2017 F450 KR
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
