Anyone that actually works a truck disappointed with the aluminum bed?? - Diesel Forum - TheDieselStop.com
 12Likes
post #1 of 38 (permalink) Old 10-23-2017, 09:14 PM Thread Starter
My Photos: (12)
Have a friend with a 6 month old "17" F250 CC 4x4. He has said from the get go that the bed dents easily. He is a general contractor and says he wishes he had his "12" back. Today he had to switch hitches and was setting the heavy 2 5/16 over the bedside. Of course these 17's are so damn tall that unless your 6'6" you can't reach the bottom of the bed. So the hitch was dropped about 6" like he has done a hundred times with his "12" Resulted in 2 holes in the bed. Either they need heavier metal in the inner bed or make it out of steel. The bulkhead is also pretty beat up from sliding ladders in the back. He's also disgusted hooking up safety chains but i found a solution for him on here. He used the "12" the same way and had NONE of these issues.
11 F250 S/C 4x4 6.2 V8
10 Expedition 4x4 5.4 3 valve.
Former trucks:
95 F350 CC PSD 5SPD Gear Vendors O/D 4x4
2003 F250 CC 4x4 6.0 HEADACHE! Traded before it blew!
89 F250 2wd 7.3 5spd with 256K when sold
94 F250 4X4 IDI Turbo 7.3 5 spd 160K when sold
95 F250 S/C 4x4 PSD 5 spd with 146K when sold
00 F250 C/C 4X4 PSD 6 Spd with 126K when sold (180K now)
mjstef is offline
post #2 of 38 (permalink) Old 10-24-2017, 12:29 AM
All of my previous 150's had the same dents, and looked beat. My 2015 F150 and 2017 F350 I've had rino lined and I haven't had an issue at all and yes I use my truck, I'm a hardwood flooring contractor so my truck is always full of tools.
Fordfan4life is offline
post #3 of 38 (permalink) Old 10-24-2017, 09:01 AM
jetboatrich's Avatar
Scheduled to get mine installed in 2 weeks, for the same concerns this post was started.... to avoid tearing up my bed and tailgate
2017 F-250, Platinum
jetboatrich is offline
post #4 of 38 (permalink) Old 10-24-2017, 09:52 AM
Phillippeterson's Avatar
My trucks with steel beds all had dents too. We ordered our current truck, 2017 F450, with factory bed lining. It has no dents currently. But it may. I really don't care either way - it's a truck, not a garage queen.
Phillippeterson is offline
post #5 of 38 (permalink) Old 10-24-2017, 12:01 PM
badbart's Avatar
I'm not a fan of the aluminum truck bodies. If you do haul anything heavy that has sharp edges there's a good chance you will get a hole in the bed. And the cost of body repairs is double that of a steel bodied truck. It shouldn't be, but many body shops are taking advantage of new Ford truck owners.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #6 of 38 (permalink) Old 10-25-2017, 06:29 PM
Mine is a garage queen, and I couldn't bear the thought of even scratching the bed. It's my "dream truck", so I want it to stay nice as long as I can. That being said, it went to the Line-X dealer just days after I picked it up at the dealer.
Aluminum is a trade off and I am sure I added weight back in that is equal to a steel bed.
But I do think a bed liner is the way to go on these Alum beds.
badbart and lawnlineman73 like this.
2017 F-350 CCSB 6.7L
[old]2002 7.3L PSD, 6spd, 4x4 Off-Road, Super Cab, Short Bed, ARE Topper, SCMT Autometer gauges, Tymar, 4" SS aero-turbine exhaust, & WW.
'73 Bronco 351 SEFI, 35's & Locked!
Jesus_man is offline
post #7 of 38 (permalink) Old 10-26-2017, 02:01 PM
TJCOX's Avatar
So much for the military grade huh?
mjstef and badbart like this.
TJCOX is offline
post #8 of 38 (permalink) Old 10-26-2017, 11:59 PM Thread Starter
My Photos: (12)
No joke eh???
Former trucks:
mjstef is offline
post #9 of 38 (permalink) Old 10-28-2017, 05:15 AM
ArcticDriver's Avatar
Aluminum Alloy is a great material for many applications but it is not going to compare to the characteristics of steel for a truck bed.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #10 of 38 (permalink) Old 10-28-2017, 10:49 PM
yan7gin's Avatar
Anybody know what type of alluminium they use? I've seen somewhere that is aircraft grade aluminum but there's a couples type lol some of those types are as strong as steel but not as friendly to play with lol
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #11 of 38 (permalink) Old 10-29-2017, 08:34 AM
badbart's Avatar
Not "aircraft grade" but "military grade" is Ford's claim. Actually there is no such term in the metal industry as several grades are used for multiple applications, but Ford uses 5xxx and 6xxx grade aluminum alloys in the truck bodies. Here's an interesting article I ran across that you may find enlightening.
?Military-grade? Aluminum - SAE International
lawnlineman73 likes this.
badbart is offline
post #12 of 38 (permalink) Old 10-29-2017, 09:19 AM
Bart beat me to it but the Comments in this article are worth reading:
https://agmetalminer.com/2016/12/26/...ate-continues/
badbart likes this.
SOLD:
post #13 of 38 (permalink) Old 10-29-2017, 11:09 PM
yan7gin's Avatar
Thats right military grade not aircraft grade my bad
Thanks for the link
F350 2002 7.3
yan7gin is offline
post #14 of 38 (permalink) Old 10-31-2017, 08:18 PM
Wobblin-Goblin's Avatar
My '03 has had Line-X since week one and I have no dents whatsoever in the bed. Of course, the bed is steel. Having said that, I would think the new aluminum bed with Line-X would provide plenty of dent resistance and also be lighter than a Line-Xed steel bed.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline
post #15 of 38 (permalink) Old 10-31-2017, 08:43 PM
Line-X really is an amazing product... We even use it on our boats which are constantly exposed to a harsh salt water environment.
I don't fully understand why a lighter truck bed is a good thing. My F250s run better when I have atleast 200# of weight in the bed compared to empty.
SOLD:
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
