Oil life indicator - Diesel Forum - TheDieselStop.com
 14Likes
post #1 of 51 (permalink) Old 05-24-2017, 05:25 PM Thread Starter
Phillippeterson's Avatar
Oil life indicator
Still haven't seen the "change oil" indicator on my 2017 F450. I have 4,000 miles on it. I plan on changing at 5,000 mile intervals anyway.
I know there is an "oil life reset" function. Is there an indication of "current oil life" that can be seen, say, before embarking on a long road trip?
FatSasquatch308 likes this.
Phillippeterson is offline
post #2 of 51 (permalink) Old 05-24-2017, 06:23 PM
manowell's Avatar
Not that I can see in the information display. It's in the truck's "brain", though, just like the DPF full level. I can see it with FORscan, mine is 70% oil life left with 2100 miles on it, of which 550 were towing at highway speeds.
Current:
  • '17 Ford F-350 King Ranch Crew Cab long bed 6.7l V8 (440/925)
  • '06 Yamaha FJR1300AE motorcycle
  • '03 Thor Jazz 2850BH Fifth Wheel
Past:
  • '11 Ford F-350 King Ranch Crew Cab long bed 6.7l V8 (400/800)
  • '08 Ford F-350 King Ranch Crew Cab long bed 6.4l V8 (350/650)
  • '04 Ford F-250 King Ranch Crew Cab long bed 6.0l V8 (325/560)
  • '01 Ford F-250 Lariat Crew Cab short bed 6.8l V10 (310/425)
  • '99 Ford F-250 Lariat Crew Cab short bed 6.8l V10 (275/410)
  • '97 Ford F-150 XLT Supercab short bed 4.6l V8 (220/290)
manowell is offline
post #3 of 51 (permalink) Old 06-04-2017, 07:29 AM
superdutyplatinum's Avatar
As far as I know so far, you only get a message that it's time to change the oil. Then all you do is rest the oil life monitor. NO % display. At least that's the way I understand it from my service department representative.
superdutyplatinum is offline
post #4 of 51 (permalink) Old 06-06-2017, 08:52 AM
wpetko's Avatar
My Photos: (17)
I'm not completely sure, but I think you get the "change oil" alert at 7,500 miles. I'm not sure about this either, but I think you can change this alert to something else as well. 'Comments?
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
post #5 of 51 (permalink) Old 06-07-2017, 10:45 AM
manowell's Avatar
You get the "change oil" alert anywhere between (roughly) 5K and 10K miles depending in severity of service and driving. Towing a lot, you'll get it quicker. Smooth 60 mph highway driving empty, I've seen it go longer. They're calculating that somehow, not sure if it's actually based on looking at the oil or just hours/miles/power requested/boost or something.
Current:
Past:
manowell is offline
post #6 of 51 (permalink) Old 06-09-2017, 07:38 AM
Send a message via Yahoo to pipeliner345
My method is i use TRIP ONE as my oil change monitor. Set at zero at oil change. Then at 7500 i change.
Full synthetic.
Sent from my SM-N920V using Tapatalk
2011 F-350 6.7 CC DRW 4X4
2011 40' stoneridge 5'er
2011 21' shallowsport bahia
2008 F350 6.4 CC DRW 4x4 ---sold good truck
2003 F350 6.0 CC DRW 4x4 ---sold (POS)
1999 F250 7.3 CC SRW 4x4 ---sold best one YET!
pipeliner345 is offline
post #7 of 51 (permalink) Old 11-21-2017, 08:27 PM
8000 miles of strictly towing and no alert yet.Will keep running it till it prompts me to change it and I will report back on the mileage.
MrTommy likes this.
redlandtrucking is offline
post #8 of 51 (permalink) Old 11-22-2017, 01:46 PM Thread Starter
I changed the oil in the F450 at 6500 and 13,000 miles. I reset the oil life indicator to zero. But I've never seen the oil change alert. I'm going to change again soon at 19,000 miles, but won't reset the oil life indicator so I can at least see it once and see when it thinks I should change the oil.
post #9 of 51 (permalink) Old 12-17-2017, 02:56 PM
FatSasquatch308's Avatar
It would have been nice to see a display option to know where you stand. I am just over 5K with 3K under load. Plan on taking a trip to Florida (not towing) for the holidays and don't want to get half way there and be told my oil life is spent or close to it before I get home. I'm guessing by some of these posts, the oil life should be fine??
2017 F350 STX CCLB BLACK
2017 Yamaha YXZ 1000r SS SE
FatSasquatch308 is offline
post #10 of 51 (permalink) Old 12-18-2017, 10:48 AM
Guys....... very simple to do. Use trip A OR B. For your oil life at a glance. When i change oil i reset trip A. it is my dedicated oil life indicator.
Sent from my SM-N950U using Tapatalk
post #11 of 51 (permalink) Old 12-26-2017, 03:02 PM
I've got ~8K miles (mostly highway, only limited light towing) and FORScan tells me I'll get hit with an oil change message in about ~2K miles (not sure EXACTLY what the last number was).
Phillippeterson likes this.
roadPilot is offline
post #12 of 51 (permalink) Old 01-11-2018, 12:31 PM
It was pretty much on the money. At 9,4xxx miles, I got the "Change Oil Soon" messages. FORScan told me I had about ~550 miles to go before "Change SOON" becomes "Change NOW".
post #13 of 51 (permalink) Old 01-15-2018, 12:05 AM
Painted Horse's Avatar
Interesting that a lot of the 2017 models are getting around 10,000 miles per oil change.
My 2011 and 2015 both would prompt around 7500 miles. Must be some programing changes in the computer
When the 6.7L first came out. A Ford engineer was online telling how they ran a LOT engines way past 10,000 miles with out the oil wearing out. 7500 miles was more of compromise to be safe than the avg of worn out oil.
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #14 of 51 (permalink) Old 01-15-2018, 09:56 AM
lincster's Avatar
My Photos: (29)
Wow, just crazy to me that oil is being ran 10,000 miles.
I personally won't do it.
2019 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Agate Black, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
2012 F350 CC, DRW, FX4 - Sold
lincster is offline
post #15 of 51 (permalink) Old 01-15-2018, 01:06 PM
ArcticDriver's Avatar
I would think oil life is more a function of the specific oil than the type of engine.
jaso likes this.
SOLD:
ArcticDriver is online now
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
