Power DC fuel pump off trailer plug - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-11-2017, 06:11 PM Thread Starter
Need help here. I know it has been discussed that getting 12V to the hot pin on the 7 pin trailer plug takes some tricks. I tried plug in, start truck, press brake... no luck. fuses appear to be good.
What i am trying to accomplish is power my DC fuel transfer pump off the 7 pin. I have it wired with positive to the 12V pin, and NEG to Ground as it should be. all other spaces are empty. When i plug it into an older GMC we have, it works perfect. on 3 of our new fords... no juice. whats the trick?
17 F350 Lariat Long Bed Bronze Fire. Bradford Built Flatbed with boxes.
KSingl is offline
post #2 of 5 (permalink) Old 10-12-2017, 03:19 PM Thread Starter
For now i have it powered through the trailer marker lamps. seems to be working fine as it is a 20 amp pump, and the fuse for the trailer marking lamps is a 30 amp.
KSingl is offline
post #3 of 5 (permalink) Old 10-14-2017, 09:10 AM
wingnut60's Avatar
Assuming you don't have the Upfitter switches to use?
2017 F450 KR
2010 F450 Lariat 4x4--died, but reborn, traded
2009 F450 Lariat 4x4--died, scrapped
2007 F350 KR DRW CC 4x4-Gone to pasture
2015 Mobile Suites 38RSSA--hoping for another 10 years
2005 Mobile Suites 36TK3--traded, 10 years of camping memories
wingnut60 is offline
post #4 of 5 (permalink) Old 10-14-2017, 09:33 AM
MX727's Avatar
I do have the upfitters. I could run a line back to the pump. Problem I have with that solution is the tank is not permanent installation. I ususally set it in the rear, get 100 gallons and transfer it to my 500 gallon tank back at the farm. Around here it cost more to have off road diesel delivered than on road diesel costs at the pump.
I think I'm going to add a resistor in the brake and light circuits on the plug to trick the truck into seeing a trailer. I don't run with it hooked up anyway, just while I'm sitting moving fuel.
2000 F350 Lariat, Black with Tan Interior
2004 F350 Lariat, White with Gray Interior
2007 F350 Lariat, Red with Black Interior
2014 F450 DRW Lariat, Ruby Red with Black Interior
2017 F350 DRW Lariat, Graphite with Black Interior
2019 F450 DRW Lariat, Graphite with Black Interior
MX727 is offline
post #5 of 5 (permalink) Old 10-16-2017, 10:25 AM Thread Starter
the pump sits stationary and is used by several trucks in our yard. an AC pump would have been ideal...however someone ordered a DC pump not paying attention, and a $9 trailer plug is cheaper than an inverter. Can't return the pump either. we all have a 7 pin, so i figured that is easier to use rather than wiring every truck up to use an upfitter or switch. at that point i'll go buy an inverter. Wired up to the trailer tail lamps is working, but i want to know how to run the 12V off the trailer plug for my other trailers charging the batteries. Does the system need to sense a trailer WITH brakes to work?
KSingl is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
