Tire Valve Stem Troubles - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By ford_doctor
post #1 of 12 (permalink) Old 09-13-2018, 07:58 AM Thread Starter
Has anyone had troubles with the valve stems on your Dually? I have a 2017 F350 that I had the stems replaced several times. Mostly the outer rear tires and now the last one was a front stem. This is the forth valve stem in a year. All were replaced under warranty. Is it the stems or wheel design?
Dave
2017 F350 Dually
safedave is offline
post #2 of 12 (permalink) Old 09-13-2018, 10:01 AM
STMPDUST's Avatar
What is going wrong? I have had Ford Duallys since 2000, and never had an issue.
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
post #3 of 12 (permalink) Old 09-13-2018, 10:39 AM
I would say they have a bad batch of stems at the shop you are using. Are they steel core stems? Are you doing some crazy mud bogging?
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #4 of 12 (permalink) Old 09-13-2018, 11:47 AM
ford_doctor's Avatar
just fix it yourself
Tall Timbers likes this.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #5 of 12 (permalink) Old 09-13-2018, 03:01 PM
RT
RT's Avatar
Is that an official Ford TSB?
RT is offline
post #6 of 12 (permalink) Old 09-13-2018, 04:21 PM
No, customer noticed the valve cap was cracked.
Jesus_man likes this.
post #7 of 12 (permalink) Old 09-14-2018, 07:48 AM Thread Starter
Ford is installing OEM stems. I was told that the design allows for dirt to get under the seal and then eventually it leaks. I have had a Dually since 01 and this is a first for me. The only difference is now I live near the beach. Not sure that is doing it though.
2017 F350 Dually
safedave is offline
post #8 of 12 (permalink) Old 09-18-2018, 07:20 PM
I have a 2018 Dually and just had my right rear outer wheel valve stem replaced. I was loosing about 5 lbs a week.
JoeA is offline
post #9 of 12 (permalink) Old 10-29-2018, 06:34 PM
Angry Leaking valve stems
This has been an ongoing issue with late model dually SD trucks. It is caused by galvanic corrosion between the nickel plated stems and aluminum wheels. There’s a SSM 47326 about using a rubber valve stem that is compatible with TPMS. This has been discussed on Ford Truck Enthusiasts forum at length.
Superdick is offline
post #10 of 12 (permalink) Old 10-30-2018, 04:47 AM
Not sure where you got the "compatibility" idea. The message is only a parts message indicating that a service kit is available that does not include the TPMS sensors which are not only separate and removable from the valve stems but expensive and do not require replacing to resolve leaking valve stem concerns. In typical Ford fashion the message conveniently leaved out the part number which would be a time saver for technicians like myself. Here...
Originally Posted by FORD MOTOR COMPANY
SSM 47326 - 2017-2018 F-Super Duty - Tire Valve Stem Leak - Valve Stem Service Kit Available
Some 2017-2018 F-Super Duty vehicles equipped with Tire Pressure Monitoring Systems (TPMS) may exhibit a leak at the tire valve stem. When making repairs to the tire valve stem, there is a service kit available that does not include the Tire Pressure Monitoring System (TPMS) sensor. When replacing the tire valve stem follow the procedure in Workshop Manual (WSM), Section 204-04A. For claiming, use causal part 1700 and applicable labor operations in Section 01 of the service labor time standards (SLTS) manual.
post #11 of 12 (permalink) Old 10-31-2018, 10:10 AM
What I meant is that the existing TPMS can be attached the the replacement rubber valve stem. The replacement valve stem # is F2GZ 1700 C. This issue has been discussed at length on the Ford Truck Enthusiasts forum under thread Rucurring Valve Stem Leaks. The number is in #210 in this thread
post #12 of 12 (permalink) Old 11-15-2018, 11:41 AM
Juzplanekrazy's Avatar
I've had 3 replaced on mine. No doubt a defect of some kind.
2017 Ford F-350 Dually 4x4
The Works
Pulling a.....
2019 37' KZ Durango Gold G371 RTL
Connected with a....
Pullrite 20K Super 5th
Going where ever we want.
Juzplanekrazy is offline
  Diesel Forum - TheDieselStop.com > 2017 & up Ford Super Duties > 2017 & Up General Questions
