1 garage door opener and 2 vehicles with homelink only 1 works at a time - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 12-01-2007, 10:10 PM Thread Starter
I have 3 vehicles, each have Homelink. It seems only 1 can be programmed for a door opener at a time. If it's working, and I program the other car Homelink, the first car Homelink no longer works. Is this as designed or am I missing something?
2004 Excursion 6.0 PSD - this one's all stock
2008 F-250 King Ranch Chrome Edition PSD
timurray is offline
post #2 of 10 (permalink) Old 12-01-2007, 10:22 PM
olddieseldude's Avatar
My Photos: (16)
Re: 1 garage door opener and 2 vehicles with homelink only 1 works at a time
I wonder if it's like car keyless entry fobs where it's necessary to program all at the same time? Could it be that someone needs to be in the other vehicles going through the same steps simultaneously, or at least all programmed before the programming cycle is completed?
RickN
(mods listed in comments under photo in above link)
olddieseldude is offline
post #3 of 10 (permalink) Old 12-02-2007, 07:09 AM
Don't most modern openers have a rotating code system? My two Genie openers do. After initial programming every time and individual opener sending unit connects with the base unit it requires the last set code. When the unit opens or closes it resets a slightly different code with that individual sender and base,so the codes rotate on each cycle never the same one. If the Homelink system works similarly then it would be impossible to use more than one sender, vehicle, per opener.
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #4 of 10 (permalink) Old 12-02-2007, 11:23 AM
Going_Going_Gone's Avatar
It can be frustrating as the process is somewhat complicated. If you hold the "button" on the opener too long, it reprograms the code and none of the Homelinks will work. After you set an individual Homelink unit, you need to push the assigned button and then the button on the opener to acknowledge the proper coding. Look in your owner's manual for the instrucions for your vehicle.
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s now gone, but greatly missed
Going_Going_Gone is offline
post #5 of 10 (permalink) Old 12-02-2007, 07:19 PM
Can't help you much. I have two vehicles with homelink, and two genie openers and both vehicles can open both garage doors just fine. I don't think I did anything special to program them.
2008 F350 CC/LB Lariat Dark Forest Green/Med. Stone 4x4 6.4/TorqShift. Heated seats, adj. pedals, cab heater, audiophile stereo, traction control, 20" wheels. Rhino Liner, B&W turnoverball w/5th wheel companion
Black Sheep is offline
post #6 of 10 (permalink) Old 12-03-2007, 07:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Black Sheep</div><div class="ubbcode-body">Can't help you much. I have two vehicles with homelink, and two genie openers and both vehicles can open both garage doors just fine. I don't think I did anything special to program them. </div></div>
Must be different model Genie openers than mine, with the rotating code system mine won't work two openers one door. When one opener uses the system it resets the code in the sender and base so the other openers are never on the same code pattern. A supposed security feature, like a garage door is Fort Knox anyway.
Oneof6 is offline
post #7 of 10 (permalink) Old 12-04-2007, 03:12 AM
SteveRacer's Avatar
Location: Rockland Co. NY KC2JLJ on 147.165 MHz Design Engineering Machine Shop Owner
I believe there is a way to do it, but it's a pain. You have to program everything at once. The opener receiver has to know about each Homelink.
I helped a coworker set this up a few years ago. Had to have both cars at the same time parked near the garage, and it took several tires and a lot of re-reading the instructions.
It helps to have one person in each car pushing the correct Homelink buttons, and a third person on the ladder pushing the programming button on the opener. You can do it with fewer people, but it's crazy trying to run around and do everything with some fairly short time windows to get it all done. Every button push has to be perfect. Make one mistake, and you gotta start over.
The Homelink instructions will tell you how to do it, or they will tell you up front which models it will never work with.
HTH
-steve
S.A McChesney
'72 BMW 2002tii Fprod Race Car --- '82 Bitter SC 5-spd
'01 Volvo V70 T5 5spd, The Official SCCA Volvo Historic Racing Series Pace Car
'95 EB 351 Bronco --- '69 Lotus Europa --- '87 Merkur XR4ti --- '85 Bitter SC 3.9</font>
Tekonsha Prodigy -- Icom 2100H -- Retrax -- B&W Turnover 5er Kingpin -- Letter to Santa "US Gear" . . .
32' invert 5er Britton/Transport Sys 12K GVWR Toybox,Honda 3kw Gen,Fridge,Micro,5kw Inverter,ColemanPolarCub
__________________________________________________ _______________________
SteveRacer is offline
post #8 of 10 (permalink) Old 09-10-2016, 09:52 PM
Your garage door can only have so many items programmed at once. For instance, if you get new cars, keypads or remotes you may max out the number of codes that can be stored. I would recommend that you reset the garage door unit. You can do this on many of them by holding the "learn" button for several seconds. This should wipe out all wireless codes that have been stored and allow you to store multiple codes again. Hope this helps...
Marc
xumrunr is offline
post #9 of 10 (permalink) Old 12-22-2016, 02:29 PM
Resolved ... I had the same issue with my Toyota 4Ruuner and Toyota Tundra. Only 1 can be programmed and the other loses it. I have a Genie garage door (with rolling code) and what finally worked is when i reset the garage door opener by pressing and holding the learn button for 10 seconds. Then programmed the regular remote control that comes with the garage door. And then reprogramming both cars as i did before. This time though both kept the code.
raynnnn is offline
post #10 of 10 (permalink) Old 07-14-2019, 04:56 PM
Of all the above articles, this is the one that works.
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
