Motofloor garage tiles from Costco? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 09-11-2019, 06:31 AM Thread Starter
My Photos: (5)
Anybody use these tiles and have thoughts on them? This is for a garage that just parks cars and has foot traffic. No real work is done in this garage.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 127,000 miles.
clydesdale is offline
post #2 of 4 (permalink) Old 09-11-2019, 02:26 PM
klhansen's Avatar
My Photos: (180)
Haven't used them, but I can see the floor covering creeping around or buckling, given it's a free floating system. Say you put a cabinet in one spot, that essentially locks it down.
You also have to do some filling and potentially grinding to smooth out the concrete prior to installation. If you're going to go that far, I'd just bite the bullet and pay up for an epoxy coating.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old Yesterday, 08:37 AM Thread Starter
My Photos: (5)
If I go with a coating, it seems like polyurea is now the way to go. It seems like a touch more expensive, but easier to work with a more durable. The beauty of the tiles is that you can just put it right down on the existing concrete. No grinding, sanding or prep required.
post #4 of 4 (permalink) Old Yesterday, 06:02 PM
klhansen's Avatar
My Photos: (180)
Not what I saw on the install instructions, but if your floor is unusually smooth, you could probably get away without prep.
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DonWarkentin
