Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   Other Technical Questions (https://www.thedieselstop.com/forums/f34/)
-   -   Need ECU help F150 (https://www.thedieselstop.com/forums/f34/need-ecu-help-f150-634689/)
Texkenusmc 12-07-2017 10:45 AM
Need ECU help F150
I just bought a 2002 f150 for $500 That has less Than 100,000 miles. Has a fried ecu. What info do I need off it to get the right one.
RT 12-07-2017 12:43 PM
I would expect them to have a sticker like our PCMs. Have you pulled it yet?
Texkenusmc 12-07-2017 02:32 PM
Not yet I will sat when I get time. I just bought and picked up from a shop it was at. I know it is a good shop so I am going off what the said the issue is.
Steve83 12-07-2017 05:02 PM
I'm skeptical of that diagnosis... I've never seen a failed F150 PCM later than '93, and even in those, it's just the 3 electrolytic capacitors that leak. The only exception would be from reversed jumper cables, in which case it's not just the PCM - it's the alternator & several other modules.
Anyway... The info you need depends on who you're buying the replacement from. But it's either the long Ford PN, or the short (4-digit) calibration code:
https://www.supermotors.net/getfile/...93calcodes.jpg
https://www.supermotors.net/registry/media/901662 (for phone apps)
Texkenusmc 12-08-2017 12:37 AM
He drove into some deep water. The shop it is at has been their for 30years and is one of the best in the area so I tend to belive them but I will check it out real good. I figured it all out I will check it over this weekend and start ordering parts Monday.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
