Need ECU help F150 - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-07-2017, 10:45 AM Thread Starter
Texkenusmc's Avatar
Need ECU help F150
I just bought a 2002 f150 for $500 That has less Than 100,000 miles. Has a fried ecu. What info do I need off it to get the right one.
Texkenusmc is offline
post #2 of 5 (permalink) Old 12-07-2017, 12:43 PM
RT
RT's Avatar
I would expect them to have a sticker like our PCMs. Have you pulled it yet?
RT is offline
post #3 of 5 (permalink) Old 12-07-2017, 02:32 PM Thread Starter
Texkenusmc's Avatar
Not yet I will sat when I get time. I just bought and picked up from a shop it was at. I know it is a good shop so I am going off what the said the issue is.
post #4 of 5 (permalink) Old 12-07-2017, 05:02 PM
Steve83's Avatar
I'm skeptical of that diagnosis... I've never seen a failed F150 PCM later than '93, and even in those, it's just the 3 electrolytic capacitors that leak. The only exception would be from reversed jumper cables, in which case it's not just the PCM - it's the alternator & several other modules.
Anyway... The info you need depends on who you're buying the replacement from. But it's either the long Ford PN, or the short (4-digit) calibration code:
https://www.supermotors.net/registry/media/901662 (for phone apps)
Steve83 is offline
post #5 of 5 (permalink) Old 12-08-2017, 12:37 AM Thread Starter
Texkenusmc's Avatar
He drove into some deep water. The shop it is at has been their for 30years and is one of the best in the area so I tend to belive them but I will check it out real good. I figured it all out I will check it over this weekend and start ordering parts Monday.
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
