Need some recommendations - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-09-2018, 09:29 PM Thread Starter
So I’ve got this 99 wrangler that I’d like to swap with a smaller Diesel engine, I’m looking for something with very few sensors and other electrical components if possible. I just need maximum power with lightest weight/ smallest size. Not really sure where to look. Would prefer an engine that I can mod to. Any suggestions would be appreciated
Flooormatt is offline
post #2 of 4 (permalink) Old 04-09-2018, 09:48 PM
RT
RT's Avatar
Your best bet is a 4BT Cummins. Easy to work on, extremely reliable, and readily available. Lots of parts in common with the 6BT that the Dodge boys use.
Sent from my iPad using Tapatalk
RT is offline
post #3 of 4 (permalink) Old 04-10-2018, 10:53 AM
Steve83's Avatar
Cummins is also putting out a crate TD engine now, specifically marketed toward Jeep swaps.
Steve83 is offline
post #4 of 4 (permalink) Old 05-29-2018, 11:58 PM
Cummins offers the R2.8 turbodiesel. Itís a 2.8-liter four-cylinder that makes 160 horsepower at 3,200 rpm and 267 pound-feet at 1,600 rpm. It is available from Cummins for $8,999. It weighs 503 lbs.
The 4BT is a 3.9L four cylinder that makes 105 horsepower and 265 pound-feet. It weighs 745 to 782 lbs. Pre-owned, they go for around $3,200 to $6295.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
