Rear LS Differential Gear Oil (used appearance) - Page 2 - Diesel Forum - TheDieselStop.com
 5Likes
post #16 of 16 (permalink) Old 05-27-2018, 10:53 AM
My Photos: (27)
I've wasted my adult life away overhauling everything from Eaton 2 speeds to many tandem axle semi differentials and never drained the oil where the last few drips didn't look like fine metallic paint particles---it's normal with mileage and age. Same with a manual transmission. And if a magnetic drain plug is used, it will always have some metallic "fuzz" stuck to it. Since Ford in their infinite wisdom didn't spec a drain plug in the axle housing, after pulling the back cover to completely drain gear oil it's a good idea to drill and tap a 3/8 or 1/2 pipe plug hole in the bottom of the housing and use a magnetic drain plug for in the future.
LMJD is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
