Start Stop Technology - Diesel Forum - TheDieselStop.com
 7Likes
post #1 of 21 (permalink) Old 08-08-2018, 01:50 PM Thread Starter
Phil G.'s Avatar
Is it just me or is having your vehicle shut off at every stop about the dumbest thing they will ever be able to come up with to save fuel? It's on just about every new gas vehicle on the market now.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #2 of 21 (permalink) Old 08-08-2018, 02:23 PM
bugman's Avatar
My Photos: (12)
Haven't seen that one yet.
bugman is offline
post #3 of 21 (permalink) Old 08-08-2018, 09:47 PM
I was in South Cal back in the 70's, you could see the L.A. smog and your eyes would burn, if you rode a motorcycle in the summer. Just too many cars and not enough air, every little bit helps. Big city drivers spend a lot of time just sitting at stop lights, If all the cars stop running for one min at every light it has a huge effect at the end of the day. I drive old stuff so I don't have to worry about the stop/start issue. All electric or hybrid is how it will work once they get a better battery.
Bugman
You don't even know the motor has stoped or started, we had a rental and it took me a while to notice it.
DENNY
DENNY is offline
post #4 of 21 (permalink) Old 08-08-2018, 10:09 PM
bugman's Avatar
My Photos: (12)
I did some reading on it after I posted. What will they think of next?
Knowing the automotive manufactures they are installing it to boost their mpg ratings rather than decreasing the smog footprint.
I've ridden in a few electric hybrids and if it wasn't for the gauges you would never know that it was running.
MrTommy likes this.
bugman is offline
post #5 of 21 (permalink) Old 08-09-2018, 12:16 AM
I have the start stop technology on my F150. There is no delay at all. It starts instantly when you take the foot off the brake. By the time you get the foot to the gas pedal, it's ready to go.
DonWarkentin is offline
post #6 of 21 (permalink) Old 08-09-2018, 06:48 AM
Mark Kovalsky's Avatar
My Photos: (6)
Why is it dumb? At idle fuel is being burned with no movement. It's wasted fuel. Why not save it?
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #7 of 21 (permalink) Old 08-09-2018, 07:33 AM
MrTommy's Avatar
It would seem to me that if you're in start and stop traffic, this involves a lot of starting which involves a lot of battery usage. Does all the stuff like a/c, radios, fans, lights, etc stay on? Maybe I'm just an old guy who remembers how easy it was to kill a battery if you left anything running once the motor was off.
MrTommy is offline
post #8 of 21 (permalink) Old 08-09-2018, 08:10 AM
RT
RT's Avatar
The cars that have the feature are constantly monitoring multiple parameters. It definitely knows the battery reserve - also monitors engine temperature, ambient temperature, cabin temperature, climate control settings, etc. My Audi won't do the start/stop thing unless the engine is warmed up and stopping the engine won't cause the cabin temperature to dramatically change during the duration it is engaged. Having said that, I live out in the country and having the engine stop every time you come to stop sign or flashing red light where you are only going to be stopped long enough to look left and right is painful.
RT is offline
post #9 of 21 (permalink) Old 08-09-2018, 08:18 AM
ArcticDriver's Avatar
That feature would result in my getting tickets for rolling stops.
LMJD and MrTommy like this.
SOLD:
ArcticDriver is offline
post #10 of 21 (permalink) Old 08-09-2018, 08:36 AM Thread Starter
Phil G.'s Avatar
I just think shutting a car off in stop and go traffic continually for 10 years is not a good solution. If RT is right and it tracks every possible parameter and disables itself such as increased current draw when the starter or wires increase in resistance as they age then maybe the freeways won't be full of disabled vehicles in 5-10 years but then it will likely throw the MIL and instead, the shops will be full and people will be paying through the nose to keep it working. If they are still doing e-tests by then, you can bet it will be required to work to pass.
It seems the more of this stuff they pile into vehicles, the more burden they put on financially strapped people that have to buy the older vehicles to begin with due to finances. Everyone that would be comfortable owning a fully loaded platinum 6.7 when it's 5 years old and has 300,000 and no warranty, raise your hand. Now everybody that would be comfortable owning an out of warranty 7.3L with 300000 on it raise your hand.... I rest my case.
There has to be better ways to save fuel.
MrTommy likes this.
Phil G. is offline
post #11 of 21 (permalink) Old 08-09-2018, 08:39 AM Thread Starter
Phil G.'s Avatar
I have no issue with it when it works perfect, I've had it in a couple of rental vehicles, my sister just bought a Grand Cherokee with it.
Phil G. is offline
post #12 of 21 (permalink) Old 08-09-2018, 08:44 AM
RT
RT's Avatar
You mean like dumping it down the exhaust to burn off soot in the DEF? I'm not sure the EPA would allow intelligent minds to come up with better ways... Personally, I'm keeping two vehicles that are so old that a electromagnetic pulse attack wouldn't do anything more than cause some static on the radio.
ford_doctor likes this.
RT is offline
post #13 of 21 (permalink) Old 08-09-2018, 08:58 AM Thread Starter
Phil G.'s Avatar
RT, don't even get me started, I did my ranting on that one back in '08 when it came out. I looked at the technology then quickly bought the leftover '07 that I'm driving today. It broke my cycle of flipping trucks every 2-3 years.
I just had to replace the cat on my truck, the guts were rattling around inside the original one. Ford here in Canada wanted over 2K for an OEM, even the online US Ford dealers wanted about 1200 plus shipping. An aftermarket POS was going to be about 700 from Rock Auto by the time it got here. I know there are some precious metals inside but over 2K when a muffler is a few hundred bucks...really?
The cycle seems to be the EPA mandates it, "we all have to do our part to clean up the world". It's now a part you can't drive without, up goes the price from the OE and the end user takes it in the $%^. If the whole world was so concerned about the environment, the OEM would say "let's do our part and make the emission stuff as affordable as possible so people can keep it in top shape, we will gouge them on some other items".
At the end of the day, just follow the money to figure out why the world works like it does.
MrTommy likes this.
Phil G. is offline
post #14 of 21 (permalink) Old 08-09-2018, 10:22 AM
Steve83's Avatar
Stop-start is rough on starters, and uncomfortable if you're trying to run the A/C. But it doesn't hurt the battery unless you hit every red light all the way to work. Otherwise, the alternator easily recharges it between stops.
The cost of replacement cats isn't the materials - it's the certifications to prove to the gubmint that it actually works the way the original did.
Steve83 is offline
post #15 of 21 (permalink) Old 08-10-2018, 07:49 AM Thread Starter
Phil G.'s Avatar
So one would think that the OEM one should be the cheapest, their certification costs would have been completely amortized when factored into the truck cost being produced at the time when they designed it. They just have to crank out more to supply the replacement market now. So once again, the Green movement spells a major opportunity for "green" for the manufacturer.
MrTommy likes this.
Phil G. is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
