Td5 oil change recommendation - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 06-09-2019, 10:53 PM Thread Starter
How often should you change oil
BruceWisse is offline
post #2 of 2 (permalink) Old 06-10-2019, 01:56 PM
Land Rover specifies 20,000km/12 months reduced to 10,000km/6 months for arduous work.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > Other Topics > Other Technical Questions
