High-pitched whine sound under acceleration - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 18 (permalink) Old 08-24-2009, 03:19 PM
creepytc's Avatar
Well, I got my truck back and they said it was a split in one of the boots going to the turbo. Not the turbo it self. Still covered under waranty. I didn't hear it on the way home but I'll keep up on it and see if it comes back.
2008 F250 King Ranch Crew.
creepytc is offline
post #17 of 18 (permalink) Old 08-25-2009, 12:38 AM Thread Starter
SFC1984's Avatar
Did they say what the cost would be if not under warranty?
SFC1984 is offline
post #18 of 18 (permalink) Old 10-21-2019, 12:58 PM
Valve cover mounting stud for turbo sheared
I had the same symptoms. However, I had a different cause. The U-shaped "hose assembly" had backed out of the air duct due to the shearing of the mounting stud which mounts to the valve cover. The stud is part # W302461. The upper front one (easiest to get to) was sheared allowing a gap between the hose assembly and the air duct.
Easy to get to. Took about 1 hour. Had to loosen all 4 stud mounts to get the one out. A set of new studs is only $18.
I knew where to look because last year, all 4 studs broke causing the hose assembly to back completely out and I lost my turbo. That was a 4 hour fix. Mostly just taking off all the stuff so I could get to the bolts.
dlinafelter is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
