P2563 code after ebp sensor and tube replacement - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 10-19-2015, 09:49 PM Thread Starter
Lenny1's Avatar
Been haven issues with this for awhile now replaced 3 ebp sensors thinking maybe I was getting bad ones and still doing it. Start truck up and have the normal hiss from exhaust drive it seems to run good then I start noticing boost is lower then normal and stop and get out no more hiss. Just a rumble. Checked turbo vain controller moves freely, turn key on and it cycles , cleaned map sensor and that other sensor beside it on the intake ,pulled intake off checked turbo it spins freely and very lill play in the shaft. Anyone have any ideas for me? Since it s going to be getting colder soon this is only going to get worse . Any suggestions would be great
Lenny1 is offline
post #2 of 18 (permalink) Old 10-20-2015, 06:54 AM
very little play in the shaft is too much play in the shaft... just sayin'....
Look carefully around the down pipes, look on the firewall for soot, as well as on the back of the engine in the case they're ruptured on the front...
also, carefully inspect all the boots for ruptures...
hit the inter cooler with a spray bottle of dish washing soap and water in a strong mix, and rev the truck a few times to see if it bubbles..
drewactual is offline
post #3 of 18 (permalink) Old 10-20-2015, 08:12 AM Thread Starter
Lenny1's Avatar
You think the problem might be a intake or exhaust leak? I was thinking electrical issue but I am not very good at diagnosing that. I do see some soot around the egr delete on driver side but can't seem to find where it is comeing from. Also would a leak make it throw that code and give me all the issues?
Lenny1 is offline
post #4 of 18 (permalink) Old 10-20-2015, 10:30 AM
the tube your sensor is tapped into is likely clogged... I don't read too well, it appears- or, i don't comprehend what's being said too well.. either replace the tube (they aren't that much) or take it out and clean the pejesus out of it.
post #5 of 18 (permalink) Old 10-20-2015, 12:46 PM Thread Starter
Lenny1's Avatar
I replaced the tube and put a new sensor in. Soon as the weather cools down truck runs ****ty again. Anybody else have a idea for me?
Lenny1 is offline
post #6 of 18 (permalink) Old 10-21-2015, 05:08 AM
ford_doctor's Avatar
Why are you replacing EBP sensors? The DTC P2563 relates specifically to the turbocharger actuator and position sensor or the turbocharger itself. The fact that the actuator moves is a good sign but you need to be capable of commanding the actuator with a scan tool and monitor the position signal to accurately diagnose this. If you caused this code during the EBP replacement then a harness or connector issue is suspect.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #7 of 18 (permalink) Old 10-21-2015, 11:09 AM Thread Starter
Lenny1's Avatar
I found a leaky up pipe last nightwhere the flex meets the pipe on the driver side. Could this be my hole problem with throwing this code Nd haven boost issues?
Lenny1 is offline
post #8 of 18 (permalink) Old 10-21-2015, 03:57 PM
It would be a good idea to repair the leak and then prove it out.
post #9 of 18 (permalink) Old 04-01-2016, 06:37 PM Thread Starter
Lenny1's Avatar
Update on this fixed all exhaust leaks and did the ebp relocate to back of motor put all new cac boots on. And still have this problem 2563 code and boost lower then normal when truck warms up. It's only - 3 here and it doing it. Soon as truck comes to opp temp the hiss goes away and sounds like a rumble and turbo very laggy. Any ideas guys?
Lenny1 is offline
post #10 of 18 (permalink) Old 04-08-2016, 01:51 PM
diesel dave 99's Avatar
just ran into that code I had to replace the turbo Actuator code gone truck runs good not cheep $436
08 F-350 Crew Cab Dually 4X4 Lariat 6.4 4:10 gears. [email]
diesel dave 99 is offline
post #11 of 18 (permalink) Old 04-11-2016, 09:18 PM Thread Starter
Lenny1's Avatar
How did you diagnose the actuator ? And did yours move freely diesel Dave?
Lenny1 is offline
post #12 of 18 (permalink) Old 04-13-2016, 10:30 AM
it did move free and it even cycled when you turn the key on But it must have had a dead spot in it.
post #13 of 18 (permalink) Old 05-03-2016, 07:55 PM Thread Starter
Lenny1's Avatar
Replaced turbo actuater and it's still throwing 2563 code. So sick of chaseing this issue already. Soon as truck warms up at highway speeds it throws the code pull over and get out truck just makeing rumble from exhaust wait like 30 seconds at idle the hiss slowly comes back again. And it's fine . Soon as I get back up to high way speeds code comes back and the rumble again . Them it clears it's self after a few seconds and hiss comes back from the exhaust . Anyone have any ideas here to throw me in some kinda direction?
Lenny1 is offline
post #14 of 18 (permalink) Old 05-06-2016, 08:33 AM
lari2001's Avatar
I tale it you have an aftermarket programmer on it? Could the isdue be with that?
lari2001 is offline
post #15 of 18 (permalink) Old 05-08-2016, 10:03 PM Thread Starter
Lenny1's Avatar
Yes I do been fine for 5 years now so I don't think it could all of sudden be the programmer I am thinking a it's either wireing or the pcm. But trying to stay away from the dealer with here high price diagnose would like to diagnose myself but pretty much tryed everything I could think of
Lenny1 is offline
  Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 6.4L Power Stroke Engine and Drivetrain
